Opinion on these hid conversion headlights.
Old Feb 9, 2021 | 01:32 PM
Dirty_Duke's Avatar
Car: 91 firebird formula ws6
Engine: TPI 305 (R6P)
Transmission: R6P t5 5 speed
Axle/Gears: 3.42:1 Posi Diff
I got a 91 firebird formula and the stock lights are dim as hell, just wondering if anybody had experience with these headlights:https://www.hidnation.com/products/h4666-hid-conversion-kit
I'll also take suggestions for different ones, I just don't wanna screw around with my wiring and I want them to look somewhat stock like these. Also I want them to last! So if u have used these, give me your opinion
Old Feb 9, 2021 | 01:47 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Opinion on these hid conversion headlights.
Those are garbage and should not be marketed for that use. They are reflectors with a lens in front. You will be blinding the oncoming traffic
Morimoto has a bi LED in the 4666 size housing. I got mine from The Retrofit source
Old Feb 9, 2021 | 04:04 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I got mine from Headlight Revolution.
Old Feb 10, 2021 | 01:57 AM
Dirty_Duke's Avatar
thanks for the input, are these "plug n play" ? And are there any that look closer to stock? Also I don't know Jack about headlights so is $225 about what these all run for?
Old Feb 10, 2021 | 08:28 AM
They're as close to plug-n-play as you're going to get for something like these. If you aren't comfortable changing out the plug, you can get a small adapter that will work. The lights have H4 plugs. They fit in the housings of a '91-92 Firebird perfectly. They are the only hi/lo LED that fits our headlight buckets. I've had them on my car for a couple months now. They are awesome! They look fairly close to stock, but if they're off you don't see them anyway. If they're on, all you see is light. Oh, and they don't blind oncoming traffic either like a lot of HID and reflector type headlights. BTW, that's $225 for each one. But they are IMO the best lights on the market for the '91-92 Firebirds.
Old Feb 10, 2021 | 09:58 AM
Reddragon88gta's Avatar
Engine: 5.7 L98
I just saw this, I thought the same thing with the factory lights the first time I drove at night with my GTA. My solution, which is plug and play, was to replace the factory lights with Silverstars by Sylvania. They are a big improvement over factory and they plug right in and serve me well for the limited occurrences when I drive mine at night. I can't remember the price but they should be under $50.
Old Feb 10, 2021 | 12:49 PM
Dirty_Duke's Avatar
how's the light pattern on those? And they have high beams too, right?
Old Feb 10, 2021 | 12:53 PM
Dirty_Duke's Avatar
They sound great but holy crap $450 is a ton of money to spend on headlights! If I go for those, I'd have to wait since I was planning on finishing my paint before I do any mods, but the stock lights are just so damn dim.
Old Feb 10, 2021 | 12:57 PM
Dirty_Duke's Avatar
wow, are these really that good? They are 20 bucks each... I'd be worried about quality because of the super low price...
Old Feb 10, 2021 | 01:02 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
My experience is they are just really bright halogens with a slightly different color temperature to make them more white than yellow. Better than halogen, but nowhere near as good as a proper projector LED or HID. If you decide to stay with any kind of sealed beam you should consider doing a headlight relay upgrade to get the voltage to the bulbs higher. This helps even with plain halogen bulbs
Old Feb 10, 2021 | 02:49 PM
Engine: 5.7 L98
They do have high beams, the light pattern is similar to the factory beams and I have had no issues with quality and have had them on my car about 3 years going on 4. Worst case you hate em' and are out $40 but if stock appearance and not modifying wiring is important they are a good option IMO.
Old Feb 10, 2021 | 05:01 PM
Used the Sylvania Silverstars for a couple decades now. Honestly I consider them stock replacements. Yeah, they'll be a lot better than whatever dim bulb you have now. But sooner or later they'll become the same dim bulb you are replacing. Just a hunch, but I bet it will be a while before I have to replace my Morimotos, and my beam pattern & brightness are FAR superior to any Silverstar bulb. Its more money, but well worth it.
Old Feb 10, 2021 | 10:07 PM
Drew's Avatar
Old Feb 11, 2021 | 09:58 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Old Feb 12, 2021 | 02:34 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Silverstars are still a halogen light. The drawback to them is lifespan. The way sylvania makes them brighter, (but still 55watt) is by making the filament thinner. This makes it burn brighter, but reduces the life of the lamp.Anyway, that said they are a good alternative if you're not willing to go the HID/projector lamp route.
mikey8494
Apr 7, 2014 03:00 PM
scarstellstorie
Feb 19, 2008 11:34 PM
Gambit69
Oct 7, 2004 09:29 PM
dwish8990
Jun 23, 2002 08:26 PM
