yellow vss buffer box delete
Old Mar 14, 2021 | 08:21 PM
msammy93's Avatar
Car: 1988 Trans Am GTA
Engine: 383 TPI
Transmission: 700r4 3000 stall non-lockup
Axle/Gears: 12 Bolt Rear 3.73
So right now I have a SGI-100BT dakota box installed along with the yellow factory buffer box. I want to just delete the factory box. The problem is that there are two signal wires, purple and yellow. I am using the purple wire as my signal wire. What do I do with the yellow wire?
Old Mar 14, 2021 | 08:49 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: yellow vss buffer box delete
Did you search, at all?
https://www.thirdgen.org/forums/ltx-...uffer-box.html
Old Mar 14, 2021 | 10:12 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
What does a SGI-100BT do? I can look it up but I actually want to hear your answer.
Transmission speed sensor has a 2-wire pair. You need both to operate the speedometer. On my 89 Firebird V6 the purple and yellow were laid in the harness but not used (came from C100 bulkhead on the driver side firewall). Speed sensor was actually a different wire pair from the passenger side kick panel I think. You might want to confirm that you don't have something goofy like that going on in your car.
Old Mar 14, 2021 | 11:29 PM
msammy93's Avatar
Engine: 383 TPI
the SGI box replaced the factory vss buffer box and you can customize the signal output to make changes for tire size and rear gear changes.
Old Mar 14, 2021 | 11:30 PM
msammy93's Avatar
Engine: 383 TPI
I have read that thread already. What I want to know is if I can delete the yellow wire, or do I need to wire in the yellow wire somewhere? I thought the yellow wire was a ground but everyone says it is a low signal.
Old Mar 15, 2021 | 09:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Ground the yellow wire. I would do it at the same location that the dakota box is grounded.
RBob.
Old Mar 15, 2021 | 12:49 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
One wire to INPUT the other to SPD-
Old Mar 15, 2021 | 02:43 PM
msammy93's Avatar
Engine: 383 TPI
For anyone that suffers from the infamous bouncing speedo, deleting the yellow buffer box and grounding the yellow wire to the SGI ground fixed the issue for me.
Old Mar 17, 2021 | 06:14 PM
Diabeetus_Prime's Avatar
Car: 1989 Trans Am 60k Miles
Engine: 305 TPI 210/218 cam and V3Si blower
Transmission: T56 Swap
Axle/Gears: 10 Bolt w/Yukon Duragrip and 3.73s
^What msammy93 said. When I did my 3.73 swap with my 700r4 my speedometer would constantly bounce around when stopped. After my T56 swap, I hooked the yellow wire (reference wire) to the sensor ground on my Dakota Digital SGI-5E. All is well now.
Old Mar 17, 2021 | 06:50 PM
msammy93's Avatar
Engine: 383 TPI
Yeah it weird some of the fixes people were trying. I was seeing some guy on YouTube wrapped his purple and yellow wire in foil and then grounded it on one side lol
tlgrooms
Jan 13, 2022 08:02 PM
J_question
Apr 4, 2020 11:18 PM
Rickj350RS
Jul 11, 2004 11:08 PM
