Random broken wire... ground ?
Old May 3, 2021 | 02:58 AM
KR81's Avatar
I have this broken wire on the firewall, my guess is it would be a ground wire, is it factory ? Not having any issues that would be caused by a bad ground...
Any ideas ?
Old May 3, 2021 | 06:58 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Random broken wire... ground ?
It's a ground. Should connect to the back of the cylinder head...
EDIT: That ground strap is available new at most local auto parts stores...
Old May 3, 2021 | 10:16 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
That's the only ground for all the body related items. The engine, trans and exhaust are all isolated from the body.
Old May 3, 2021 | 06:46 PM
KR81's Avatar
Would you think I'd be having electrical issues without that ground connected ? I can only assume someone in the past has maybe attached one somewhere else to replace it ?
Old May 3, 2021 | 08:41 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I forgot, there might be one from the main battery cable too, but that one is quite small gauge compared to that braided strap
Old May 5, 2021 | 01:05 AM
KR81's Avatar
With this braided one cut, what sort of problems would you assume someone would be having?
Old May 5, 2021 | 06:54 AM
T.L.'s Avatar
Might not cause any problems. It's not the only ground, but it's a real good idea to have it. Get a new one and move forward...
Old May 6, 2021 | 03:26 AM
KR81's Avatar
Just wanted to know for the sake of knowledge.
Does it have to be the exact same type of braided wire or can I just pick a reasonable gauge piece of cable and use it ?
Old May 9, 2021 | 04:31 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
If you haven't already replaced it, then, yes, for that engine-to-chassis ground strap, you can replace it with another strap or a cable, either one, whichever you prefer to use. Straps are more flexible and less invasive for a tight space, but I like the insulation around a cable, personally. But whichever, it will be better to use heavier gauge than that wimpy OE strap, a gauge that equals or is close to the main negative battery-to-block cable. That's what, 4 gauge, if your cables are OE? Straps are available in heavy gauges and so are cables.
Upgrading that ground strap is the 3rd piece of the "Big 3 Upgrade." The other two pieces are heavier gauges for the positive battery-to-alternator cable and the negative battery-to-chassis cable, both of which are pretty wimpy, especially the stock battery-to-chassis cable. But even if you don't do all of that, then, at least, while you're replacing it now, upgrade that wimpy ground strap.
And for a "Big 4 Upgrade," add a ground cable attached to the rear of the alternator case(or to one of its mounting bolts), and connect it directly to the negative battery terminal. Use the same gauge as the positive battery-to-alternator cable(which, itself, is wimpy and should be upgraded, too).
Old May 9, 2021 | 09:44 PM
KR81's Avatar
Thanks for the advice! Yes 4 gauge is what I was thinking for it.
Crall13
Mar 15, 2015 11:35 AM
Spd-Kilz
Aug 9, 2011 10:24 AM
rjpbboi
Dec 20, 2006 06:13 PM
rjpbboi
Aug 8, 2006 09:46 PM
Berlinetta
Feb 11, 2005 04:12 PM
