1989 Camaro Uncommon Tach problem
Old Oct 3, 2021 | 12:13 PM
Squidlox's Avatar
As im not very good at explaining things i took a short video to show the issue I am having, id like to learn how to diagnose and fix what is wrong here.
Old Oct 3, 2021 | 06:25 PM
Squidlox's Avatar
Re: 1989 Camaro Uncommon Tach problem
Update video:
Old Oct 3, 2021 | 06:50 PM
vorteciroc's Avatar
Top Answer: 1
No that is not operating properly.
Is the Oil Pressure Gauge also stuck/ frozen?
If so, there may be a poor connection to the Gauge.
Old Oct 3, 2021 | 07:01 PM
Squidlox's Avatar
oil pressure gauge will return when moved
Old Oct 4, 2021 | 12:41 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Either it's not getting a good signal from the distributor, or it's not getting a good power / ground through the pcb / clips / poles in the instrument cluster. I'd probably check the wire from the distributor first, and if that checks out I'd pull the cluster and inspect for corrosion (a good time to replace all the bulbs!).
Old Oct 4, 2021 | 06:49 PM
Squidlox's Avatar
Update: i used the wrong resistor like a dummy, so i went to 200k resistance, just to see what would happen and this is my result:
Old Oct 4, 2021 | 11:23 PM
vorteciroc's Avatar
Top Answer: 1
Well, that was better...
Can you please tell us, how the Tachometer RPM Signal Circuit is wired?
What did you modify?
Where did you install a 200,000 Ohm Resistor?
Old Oct 5, 2021 | 07:17 PM
Squidlox's Avatar
I added a new 180k resistor to the Curcut Board between pins 4 and 10(replacing the previous 200k), just like the 90-92 mega thread about the issue and it seems to be pretty close to correct now.
Old Oct 5, 2021 | 11:40 PM
vorteciroc's Avatar
Top Answer: 1
If you have an Ignition Timing Light that displays the Engine Speed...
You can compare the actual Engine RPM to your Tachometer RPM.
rusty vango
Aug 15, 2025 04:42 PM
berryghardwick
Feb 25, 2007 05:05 PM
RS'er
Jul 1, 2002 01:02 PM
