1986 IrocZ MAF burnoff relay issues
Old Feb 27, 2022 | 01:01 PM
NORTHSLIDER's Avatar
Car: 79, 85, 87,91 TRANS AM'S
Engine: 455,305TPI,350TPI,350TPI
Transmission: MUNCIE, T-5, 700R4'S
Axle/Gears: YEP
So I've searched for an hour or so and all I find are diagrams where the relay for the burn off has 4 wires, my relay has 5 wires A-E. A and D have power when the vehicle is running. E has power all time. B has ground all times. C has ignition power. Does this seem right? I thought the computer controls ground to come on right after the vehicle ignition is off. All testing during closed loop only have code 36.
Old Feb 27, 2022 | 01:13 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1986 IrocZ MAF burnoff relay issues
https://www.thirdgen.org/forums/tech...code-36-a.html
Old Feb 27, 2022 | 01:47 PM
Axle/Gears: YEP
unfortunately those diagrams don't mach up to what I have.
Old Feb 27, 2022 | 01:49 PM
Engine: Lb9
Transmission: M20
86-89 1227165 should be the same might have different wire colors you might consult your fsm.
Old Feb 27, 2022 | 03:51 PM
Axle/Gears: YEP
So the po must have moved the wiring harness around for the burn off and the fuel pump. I tested the burn off per the troubleshooting chart and everything was working correctly. Looks like I need a new computer to fix this.
Old Feb 27, 2022 | 04:01 PM
Engine: Lb9
Transmission: M20
https://www.ebay.com/itm/1987-1991-C...-127632-2357-0
just use your chip
Old Feb 28, 2022 | 02:56 PM
Axle/Gears: YEP
cool, thanks I just ordered it. I'll let you know how it goes.
Old Feb 28, 2022 | 03:00 PM
Engine: Lb9
Transmission: M20
Old Mar 5, 2022 | 05:54 PM
Axle/Gears: YEP
well,.the ecu worked as you said it would, but my code 36 still exists. Is the code specific to the burn off circuit? Or should I be looking in other areas also.
Blue89Bird
Sep 29, 2018 09:31 AM
hawkins
Aug 29, 2010 02:29 AM
Ward
Jan 17, 2009 06:24 PM
TunedportROC
Nov 23, 2003 09:46 PM
jdrafke
Sep 19, 2003 05:11 PM
