power mirror conversion and yellow buffer box mounting
Car: 1987 trans am, 1988 Formula
Engine: 305 LG4, 305 LB9 TPI
Transmission: 700R4 in both
I have an 88 Firebird formula and I can see a provision in the fuse panels for power accessories such as power mirrors or antenna. I am looking to retrofit power mirrors. What parts and pieces would I need to hook it up in the factory slots in the fuse panel? Obviously I know Id need the mirrors and wires themselves. All I really need to see is how they were ran within the body from the factory and the proper hook up locations. Also does anybody have a good picture of where the yellow speed buffer box mounts in a factory car. Most fall out when you take the kick panel under the dash out but I would like to mount mine back where it goes. Any help would be appreciated.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: power mirror conversion and yellow buffer box mounting
I’ve seen some buffers mounted to the ecm bracket
Car: '89 Firebird
Engine: 7.0L
Engine: Lb9
Transmission: M20
I’m not sure I think there were two locations where they were mounted.
The buffer box itself has 2 sets of tabs to mount up and down or on the side flat against something
Ok thanks for the mystery solve on the buffer box..
Now let's go to question #1 for the power mirror conversion to hook into the factory fuse panel locations and the proper wire routes
