1989 AC Fan control relay
Old Apr 26, 2022 | 04:39 PM
Jaseman32's Avatar
Car: 89 RS Gunmetal Gray
Engine: 350 TBI
The radiator fan is supposed to kick on automatically when the AC is turned on regardless of engine temp. Mine is not turning on and I've blown up two compressors because of this. I think the relay in the picture is the culprit but I thought I would check in with the experts to figure it out for sure.
Mounted to the evaporator box on the passenger side.
Old Apr 26, 2022 | 05:03 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: 1989 AC Fan control relay
Old Apr 26, 2022 | 06:45 PM
Jaseman32's Avatar
Engine: 350 TBI
Yes, but is this the AC fan relay?
Old Apr 26, 2022 | 06:56 PM
That's the interior blower motor relay. Not the cause of the symptom at hand. I think the one in question is the same part #, just, that's not the one.
Meanwhile, if the fan EVER comes on, then the relay IS NOT the problem. If it comes on under certain conditions but not others, then the control circuitry is at issue, not the relay itself.
Old Apr 26, 2022 | 07:00 PM
Jaseman32's Avatar
Engine: 350 TBI
That's concerning. The fan does come on when the block gets hot enough but it does not turn on when the AC is on. It has to be a relay or fuse somewhere right?
Old Apr 26, 2022 | 09:08 PM
vorteciroc's Avatar
Top Answer: 1
Based on the description that you have provided of the Electric Engine Cooling Fan operation...
The most likely issue would be with the Air-Conditioning System Request Switch (can be a Pressure Cycling Switch, or High Pressure Switch) for the Electric Engine Cooling Fan.
I do not remember for sure...
However, I believe that 1989 TPI Cars used both a Pressure Cycling Switch and a High Pressure Switch for the HVAC System.
The High Pressure Switch, would then be responsible to act as Air-Conditioning System Request Switch for the Electric Engine Cooling Fan...
And NOT the Pressure Cycling Switch.
The Air-Conditioning System Request Switch is an Input of the PCM.
The PCM then uses an Output to Ground the Relay-Coil for the Electric Engine Cooling Fan.
I do NOT recommend "Throwing Parts at a problem".
However, I do not have a way for you to perform Diagnostics...
And the part is quite inexpensive.
Somewhere between $10 to $20.
Good Luck!
Old Apr 26, 2022 | 09:32 PM
Jaseman32's Avatar
Engine: 350 TBI
That's good info! My car is a TBI.
You said:
"The Air-Conditioning System Request Switch is an Input of the PCM.
The PCM then uses an Output to Ground the Relay-Coil for the Electric Engine Cooling Fan."
The PCM is controlling the fan because it runs when the temperature is high enough. It is not however sending a signal to run the fan for the AC which tells me nothing is telling the PCM it to send it. The only pressure switches in my AC (that I am aware of) are the low pressure switch for the Compressor clutch and the high pressure cut off on the compressor itself.
What diagnostics can I perform?
Old Apr 26, 2022 | 09:39 PM
vorteciroc's Avatar
Top Answer: 1
I am not going to type up all of the Diag Info.
Sorry.
The High Pressure Switch should be at the AC Refrigerant Compressor.
Usually a Dark-Green Wire will go from this Switch to the PCM.
The other Switch at the AC Accumulator, is the Pressure Cycling Switch.
Old Apr 27, 2022 | 06:18 AM
Jaseman32's Avatar
Engine: 350 TBI
So the PCM gets it's signal to start the fan from the high pressure switch on the compressor? I thought that was just to shut down the compressor if the pressure becomes too high?
Old Apr 27, 2022 | 06:50 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
On the TBI f-bodys the ECM has nothing to do with engine cooling fan. It is controlled by the head temperature switch in the passenger side head (along with...).
Along with the HVAC control head in the center of the dash. When the control is placed in a position that requests A/C (Max/Norm), this also grounds the wire to the cooling fan relay coil.
The head temperature switch and the A/C fan request switches are in parallel. So either one can run the cooling fan.
RBob.
Old Apr 27, 2022 | 06:55 AM
Jaseman32's Avatar
Engine: 350 TBI
Finally! Thank you! The control head activates the AC but no signal (apparently) is going to the fan. Is the HVAC selector switch (heat, ac, vent) that's broken?
Old Apr 27, 2022 | 10:08 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I can't see what is bad from here. It may be the switch lost it's ground. Remember, this switch and the head switch provide a ground to the relay coil. The relay contacts are what carries the cooling fan motor load.
For testing can do a key-on, engine-off. Then ground the head temperature switch harness connector. That should activate the relay and turn on the fan.
Can do the same for the control head switch. Grounding the correct wire should also do the same.
RBob.
Old Apr 27, 2022 | 06:28 PM
Jaseman32's Avatar
Engine: 350 TBI
I'll give it a shot, thank you!
Old Apr 28, 2022 | 09:34 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
There should be a grey wire for the AC fan, cut it and ground it out and both fans should come on right away. On my 91 that's what happened anyway, I believe it was an AC pressure switch
Old Apr 29, 2022 | 08:32 AM
Jaseman32's Avatar
Engine: 350 TBI
Where did you find the wire? Was it in the interior or engine bay? I believe my problem is the HVAC control head not sending the ground to the fan control relay. I have to trace that out but I haven't tried to figure it out yet, kid is getting married this weekend and I've been busy as hell.
Old Apr 29, 2022 | 08:39 AM
thatsupnow's Avatar
If you've got dual fans that wire should be on your secondary relay. The primary relay will have a dark green white stripe wire. Relays in the pics are primary on the left and secondary on the right
Attached Thumbnails 1989 AC Fan control relay-pxl_20220429_133715143.mp.jpg   1989 AC Fan control relay-pxl_20220429_133727793.jpg
Old Apr 29, 2022 | 08:44 AM
Jaseman32's Avatar
Engine: 350 TBI
I just have the single fan. I'll figure it out, thanks!
Old Apr 29, 2022 | 08:57 AM
thatsupnow's Avatar
It'll be one of those wires. Pretty sure
Attached Thumbnails 1989 AC Fan control relay-pxl_20220429_135658224.jpg   1989 AC Fan control relay-body-wiring-1_070223.jpg
Old Apr 29, 2022 | 03:45 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The OP is running TBI, is a single fan set up that has nothing to do with the ECM. You have a TPI set up that is completely different. You are leading him astray.
RBob.
Old May 2, 2022 | 09:55 PM
Jaseman32's Avatar
Engine: 350 TBI
RBob, I did the key on engine off test and found the culprit. On the electrical connector for the AC/Heat/Vent switch the last two contacts on the right are the ground and the wire going to the fan relay. The ground connector had partially pushed out of the connector so it couldn't make contact with the switch. I really appreciate your help, I could not have fixed this without it. And thanks to everyone else who weighed in, I learned a lot about these AC's.
Old May 2, 2022 | 09:59 PM
thatsupnow's Avatar
RBob.
Oh yea well when that info isn't mentioned in the OP makes it difficult. I'm also not a mind reader. So calm down. Stating the correct info right off the get go is best
JoeNooch
May 20, 2008 05:17 PM
1987camarosport
Feb 10, 2007 06:23 PM
DuronClocker
Jul 4, 2004 04:48 PM
rednkRS
Mar 28, 2003 04:22 PM
Sharpcorner
Nov 8, 2000 04:31 AM
