No fuse on fan?
Car: 1992 RS
Engine: Iron 5.7 LS
Axle/Gears: 4th gen rear, 3:42s, Torsen
No fuse on fan?
My 92 RS has a single fan and I'm planning to reuse it with my Holley Terminator. I have the relay wiring and the big hot wire that goes directly from the battery to the relay is not fused. It's definitely factory wiring. Is there a reason for this? It seems like it should have at least an inline fuse the same way the fuel pump relay wire did. I may reuse that inline fuse with the fan unless there is some reason not to. I'm going to get power for the other wire from a key-on source and use the Holley to trigger the ground.
Car: '89 Firebird
Engine: 7.0L
Re: No fuse on fan?
If it is stock, then it is fused with a fusible link. You're just not looking far enough back in the wiring to find the fusible link.
If you're certain there is no fusible link then it's not stock.
Car: 1992 RS
Engine: Iron 5.7 LS
Re: No fuse on fan?
So are those links non-servicable? Meaning if it ever did blow that fuse the section of wire needs to be replaced with an inline fuse or another section of wire with fusable link? I know it's basic stuff but something that I've never had fully explained to me.
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: No fuse on fan?
Yeah, if it fries, you chop it out and splice in a new one. Although in modern times, there now exists fuses that can handle those loads so that's an upgrade you could do if you wanted to.
Car: 1992 RS
Engine: Iron 5.7 LS
Re: No fuse on fan?
I could but it's worked for 30 years so I won't fix it if it ain't broke. Thanks for the info.
