Footwell lightning
Old Sep 11, 2022 | 08:59 AM
Mspangler's Avatar
Car: 1991 Camaro RS
Engine: 5.7 Lt-01
Axle/Gears: 3:28
Footwell lightning
So I'm trying to get my footwell courtesy lights done in my 86, I think I've found the driver side one, but I cant find the passenger side one. Can anyone help?
Driver's side
Passenger side
Old Sep 16, 2022 | 11:06 AM
scfbody's Avatar
Car: 1983 Z28, 1991 Z28 & 1985 TA
Re: Footwell lightning
If the car didn't come with them there won't be wiring for them. This kit adds footwell lighting to a car that didn't come with it from the factory. You just have to supply power and ground (driver's side).
1982-92 Camaro/Firebird LED Footwell Lighting Kit (screamingchicken.com)
Old Sep 16, 2022 | 03:10 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
My 91 Firebird didn’t come with these and I wanted to them. I used a couple of these tail light bulb sockets as their about the same shape as the notched holes in the hush panels under the dash, I used some 192 bulbs. I used a Add a fuse fuse holder to get them power. If you have a little wiring experience it’s not vet difficult, if you don’t that kit that was posted seems to be a easier way to add the lighting.
Old Feb 16, 2023 | 07:58 AM
VOODOOCHILDSJ85's Avatar
I have a 85 z28 and Im looking to add footwell lighting. where is the closest place to tap for the dome lamp switch?
Old Feb 16, 2023 | 03:20 PM
91banditt2's Avatar
Engine: 5.7 HSR
The footwell lighting kit from Screaming Chicken seem like a good option.
I used a Add-A-Fuse fuse tap plugged into the ACC fuse to power the footwell lights that I added. The ACC fuse is what powers the dome light.
Wayback Machine (archive.org)
Old Feb 16, 2023 | 05:23 PM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
I used the same connectors as @91Bandit2 and some blue led from amazon (Keiurot, blue LED lights, #194). Passenger side fits in hush panel OEM hole, driver's side was a bit tricker. It was custom fit .
But for the life of me, I can't remember how I connected them. I think I hooked them up to the OEM connectors. Definitely controlled by dash switch and door switch, so it is hooked on 20A Tail Light and 5A Inst LPS, but how... can't remember!
Old Feb 16, 2023 | 07:33 PM
I shoud have a light in the shifter, I can use a inline dimmer if i have to.
Old Feb 16, 2023 | 07:44 PM
For some reason my right green blinker light stays on when lights are on. When i put the blinker it blinks correctly.
Old Feb 16, 2023 | 11:03 PM
91banditt2's Avatar
Engine: 5.7 HSR
if you have an automatic yes you should have a light for the shifter, are you talking about using a dimmer for the shifter light or the footwell lighting?
Old Feb 16, 2023 | 11:05 PM
91banditt2's Avatar
Engine: 5.7 HSR
It would be best to stay on topic, if you have an issue with your turn signal lights either start a new thread or do a search, this site has huge amounts of info on just about anything with these cars.
Old Feb 17, 2023 | 06:30 AM
For the footwell lighting.
Old Feb 17, 2023 | 06:51 AM
91banditt2's Avatar
Engine: 5.7 HSR
The shifter light comes on with the dash/head lights, is that when you want the footwell lights to come on?
89Warbird
Members Firebirds
Aug 16, 2022 06:51 PM
Jmazz97
Apr 21, 2022 09:25 PM
92GTA
Exterior Parts for Sale
Apr 6, 2015 04:51 PM
The_Wraith
Oct 4, 2004 04:42 PM
AmorgetRS
Pacific Northwest Region
May 3, 2001 07:50 PM
