Need help with understanding transistors!!!
Old Jan 20, 2002 | 09:07 PM
92RSB4C's Avatar
What exactly do they do? How do they work?
Old Jan 21, 2002 | 09:01 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
WOW, that’s a much bigger question then I think you realize. In short, A transistor is a semiconductor device that uses a change in voltage at the BE (base, emitter) junction to control current flow through the CE (collector, emitter) junction. NOTE-Uses voltage to control current. It is in fact more complicated then that, but I’m not a teacher, so I would probably confuse you (and me) more if I tried…
I added a pic of a transistor so you can see where the BE and CE junctions are.
Edited: Apeiron is right! This is why I’m not a teacher. Brain not work to well in the morning time.
File Type: bmp
Old Jan 21, 2002 | 04:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A bipolar transistor like you've described uses current to control current. A field-effect transistor uses voltage to control current.
Old Jan 23, 2002 | 03:07 PM
mtccl's Avatar
They dress up in funny clothes and try confuse drunk fellars. Them bipolar ones are the worst. They'll hit on your girlyfriend too.
Old Jan 23, 2002 | 04:06 PM
EddieDellz's Avatar
Ill be verry frightend the day a electrical component hits on my girlfrend!!! ..
Old Jan 23, 2002 | 09:12 PM
Dr. Pepper's Avatar
Your garden variety transistor does one of two things. It either acts like an amplifier or it acts like a switch. In its nature it is a current amplifier, but with a handful of components around it that may be changed so the end result is voltage amplification. Some transistors are designed to work well as switches so you can use a small amount of power to switch a larger power, somewhat like a relay. If it is something that interests you Radio Shack carries an excellent introductory electronics book written by Forest Mims. It will give you a brief but reasonably complete explanation. They are a complex device that takes most of a college text book to outline how they actually work.
Old Jan 23, 2002 | 09:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Bah.. I could do it in a couple pages.
Old Jan 23, 2002 | 10:06 PM
92RSB4C's Avatar
Really, I'd like to read it!
sparks454
20
Sep 1, 2004 01:52 PM
TheMysticWizard
Mar 30, 2004 06:41 AM
Clutch
Nov 23, 2002 10:01 AM
Wilson
Nov 8, 2002 02:51 AM
JohnnyIROC-Z
Oct 14, 2001 02:30 PM
