Help with two wires under driver side kick panel
Old Jan 8, 2023 | 04:05 PM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
Old Jan 8, 2023 | 04:06 PM
Engine: 5.7 l98
Re: Help with two wires under driver side kick panel
Can anyone tell me where these 2 oranges are supposed to go on the driver's side kick panel????
2nd and third pic are of same wire.
Old Jan 8, 2023 | 05:38 PM
vorteciroc's Avatar
Top Answer: 1
The First Image is of the VATS Ignition Lock Cylinder Connector.
The Second Image is of the Accessory Power Connector that Plugs in on top of the IPBEC (Fuse Panel).
Old Jan 8, 2023 | 06:01 PM
Engine: 5.7 l98
Thank you! Appreciated
Old Jan 8, 2023 | 06:11 PM
Engine: 5.7 l98
one more question when i plug in acc power connector i hear something run for 2 seconds. I wrongly assumed since it was acc it was extra. Apparently not lol. Any idea what I heard run ?
possibly antenna motor?????
Old Jan 9, 2023 | 04:12 PM
vorteciroc's Avatar
Top Answer: 1
It could be anything from the LEFT Side of the Image...
My guess would be the Power Seat.
Old Jan 9, 2023 | 06:49 PM
Engine: 5.7 l98
Thanks , going to grab someone to listen while I plug in.
Old Jan 18, 2023 | 02:54 PM
Engine: 5.7 l98
Update, it was the power antenna 📡
Mspangler
Sep 22, 2022 03:29 PM
Formula1791
Aug 13, 2022 10:38 AM
battmann
Jun 13, 2021 06:09 PM
91ls1t56
Dec 12, 2018 06:19 PM
TeamPoisonOil
Jun 22, 2017 06:26 PM
