Finally doing the nuclear option
Old Sep 1, 2023 | 03:03 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
I've had issues with my ignition system, mostly revolving around the ICM, since 2015, documented on here, the longest stretch typically being about a year between failures. I've done it all in terms of diagnostics and parts replacement, testing, etc.
The only thing I haven't done is rip the whole distributor out and replace it all at once, i.e. the nuclear option (in my opinion). I've seen several others with similar issues to mine who have done this and never posted again, which leads me to assume their car stopped eating ICM's.
I thought I had a good fix recently with my heat sink added under the distributor plate, but alas, it has failed again (at about a year, again).
I have tested everything and found no obvious issues, ran all the wiring, etc. etc. etc. I'm going to check the alternator for voltage spikes, again, but don't expect to find anything. I have a new dizzy on order, with a lifetime warranty, just gonna pop it in, check the timing, and see if whatever issue was eating ICM's before will go away.
My thinking is that there just has to be something, probably small, unnoticeable, issue with the current distributor that is causing failures over time. Literally every part has been replaced at one time or another.
At least with the warranty if I have a failure I can get my money back, haha.
Starting this new thread since I know there are folks out there who are also in the same situation (or will be). If you don't see me posting back it's because all went well.
Old Sep 1, 2023 | 03:28 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Finally doing the nuclear option
Hi RedLeader289, I just replaced yet another ICM myself, and TBH my "nuclear option" plan would be to relocate the ICM out of the distributor and into it own mounting area, with a CPU heatsink and fan scavenged from an old PC. If I ever do get around to it I'll be sure to create a thread with lots of pics
Old Sep 5, 2023 | 06:32 PM
vorteciroc's Avatar
Top Answer: 1
What a sad state of the quality of these Parts TODAY.
The original ICM would have never Over-Heated so easily.
CPU Cooler Thermal Transfer Paste is also Ideal to use.
Mount a Modern CPU to a Massive CPU Cooler without it, and the CPU will Over-Heat!
Old Sep 5, 2023 | 11:39 PM
ULTM8Z's Avatar
What brand ICMs are you guys buying that are failing all the time?
Old Sep 6, 2023 | 06:35 AM
Car: 1983 Z28
all of them.
MSD. Standard. AC Delco. Napa. Duralast.
Old Sep 6, 2023 | 08:31 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
While I'd guess they are not manufacturing them, does anyone have any experience with the Davis Unified Ignition (DUI) modules?
https://performancedistributors.com/...d-distributor/
Old Sep 6, 2023 | 08:48 AM
ULTM8Z's Avatar
Delcos are failing? That is surprising.
Any rate, I've been running Pertronix for a while now and no issues. Large cap HEI. I also use thermal compound under it, similar to what vorteciroc showed a few posts earlier.
Old Sep 6, 2023 | 09:07 AM
Car: 1983 Z28
that’s why I think it’s something minuscule in the dizzy itself, cuz I’ve tried everything else.
Old Sep 6, 2023 | 09:44 AM
ULTM8Z's Avatar
One thing I also did was to add a small braided ground strap to the housing and tie it back to my main ground point at the back of the cylinder head. I don't really trust the distributor clamp to provide a solid ground for the housing, which then goes back through the manifold, bolts with sealer on them, etc...
Old Sep 6, 2023 | 10:20 AM
Car: 1983 Z28
Where on the housing did you tie to? Since I’m going to have it out I figure I might as well do this too haha
Old Sep 6, 2023 | 11:57 AM
ULTM8Z's Avatar
On the bottom of the distributor housing, I drilled a small hole in a spot that won't interfere with any internal components. Then used a self tapping screw to attach the ground strap with a ring lug.
It was a small generic braided strap I got from the local auto parts store. Then ran that strap to a ground stud on the back of the cylinder head where all my other grounds are co-located.
Old Sep 8, 2023 | 05:29 PM
Car: 1983 Z28
Update. New distributor in. Car runs like a scalded dog.
no clue what was up with the other one, but there ya go.
Old Sep 8, 2023 | 05:34 PM
NoEmissions84TA's Avatar
What brand did you go with?
Old Sep 8, 2023 | 06:36 PM
Car: 1983 Z28
Duralast gold from autozone, has a polished aluminum base/shaft, cap with brass terminals, and has a lifetime warranty.
Old Sep 9, 2023 | 12:35 AM
vorteciroc's Avatar
Top Answer: 1
I didn't think there were any good Brands for the ICMs/ HEI Modules...
I gave up on them years ago, but if you guys found something reliable, please post it.
Thanks!
Many years ago when I started my Business, I only offered component rebuilding (Distributors, Carbs, TBI Units, Fuel-Pumps, Oil-Pumps, Alternators, Starter-Motors, Etc)...
I used to offer the Pertronix Module for Points Distributor rebuilds.
Half of them would just die without warning 12-Months later... Others lasted for years and years.
Old Sep 9, 2023 | 08:11 PM
DynoDave43's Avatar
The Pertronix in my brothers 914 is the current suspect in several drivability issues.
Old Sep 10, 2023 | 02:40 AM
vorteciroc's Avatar
Top Answer: 1
O jeez!
I wish you luck there!
I was just recently looking at an ICM for Large Cap HEI (4-PIN) from MSD...
I actually like some of the Design aspects (Particularly Grounding).
It's probably also a piece of junk... but I'd be interested in trying one based on design alone.
Old Sep 10, 2023 | 09:47 AM
skinny z's Avatar
All of this makes me edgy when contemplating getting a programmable distributor so as to lose the weights, springs and vacuum can features I presently have.
I've an old and ancient MSD small cap distributor and a 6AL box. It all works very well but is tedious beyond belief to tune.
No HEI for me though but that's just a personal preference.
Duralast gold...
What do you do for a timing curve?
Old Sep 10, 2023 | 11:14 AM
Car: 1983 Z28
I just used a timing light and set it to GM specs for my crate engine. Nothing fancy
Old Sep 10, 2023 | 01:18 PM
skinny z's Avatar
Fair enough.
While (I'll assume) you might have to get into the springs to make the curve correct for what GM asked for, I found one of the limitations of the HEI was the lack of being able to reduce the amount of centrifugal advance that's available.
It doesn't appear to apply to your application (which is great to have a drop-in distributor ready to go), but for me, all of the advance is front loaded (18-20° initial) and the centrifugal adds another 14° or so for the total. IIRC, an HEI has better than 19° baked in and no reasonable means to reduce that. Reasonable meaning not having to weld up the advance slot and work from there.
Once you're satisfied with the ICM surviving, would you post your results rather than the negative response approach? It keeps the flow of information intact with the problem, probable solution and results all tied together.
Good luck.
Old Sep 10, 2023 | 02:22 PM
Car: 1983 Z28
Fair enough.
Good luck.
Its been in for a couple days, I’ve taken the car on a couple drives and let it idle in the driveway, etc and it seems to be fixed.
No stumble on acceleration, idling where I set it, starts right up and idles happily (hot or cold).
As far as my timing curve, etc, that’s a bit out of my range of understanding, just being frank. I know it has an adjustable advance canister but I didn’t even mess with it.
Old Sep 10, 2023 | 03:00 PM
vorteciroc's Avatar
Top Answer: 1
What is the issue with tuning it?
Coil Dwell is the only aspect that you have no control over.
Old Sep 10, 2023 | 03:32 PM
skinny z's Avatar
Before I sidetrack the OP's thread, what tuning are you referring to? If it's mine with old school technology (springs, weights, limiting bushing, adjustable vacuum advance cans, vacuum advance limiting plate....etc.) it's gets old working on these bits.
It was different when I had this at my disposal.
But I don't any more. Now I have to lean over the fender...
As for the HEI, the lack of a limiting bushing is problematic. More tedium to make it custom.
Old Sep 10, 2023 | 05:17 PM
skinny z - your distributor is set up the same as mine is - as in NO ICM at all.
The magnetic pickup triggers the MSD box directly.
Old Sep 10, 2023 | 05:25 PM
skinny z's Avatar
Yes sir. That would be the case.
It does add some complexity as it's not exactly a stand alone HEI.
That said, I know too that the CD box isn't necessary given what's available otherwise however as our OP has witnessed first hand, it can be incredibly frustrating working through this kind of stuff even without the added complexity.
That my combination of parts has done yeoman service for the more than two decades is what keeps it in the game.
Old Sep 10, 2023 | 05:27 PM
Car: 1983 Z28
You’ve piqued my curiosity.
What kind of set up are you running?
Old Sep 10, 2023 | 06:00 PM
We are talking about an old-school 20+ year old MSD (non digital) box wired directly to the distributor's magnetic pickup coil via the green and purple wires from the MSD box.
Edit: it looks like you can also do this using the MSD digital box. Failure rate of those boxes ???
Download this manual: MSD IGNITION Wiring Diagrams and Tech Notes | PDF | Distributor | Ignition System (scribd.com)
Old Sep 10, 2023 | 06:11 PM
skinny z's Avatar
I've an MSD 8461 distributor which has been obsolete for years. It has no module and relies on the ignition box to do that job.
It's been replaced with the 8361. Same functionality though. It too requires an ignition box.
https://www.holley.com/products/igni...let/parts/8361
The ignition box is an MSD 6AL. Wired together they function like an HEI or other conventional electronic ignition. Just with no ICM.
My CD box is also old and has been superseded with the Digital 6AL.
https://www.holley.com/products/igni...eet/parts/6425
I bought a cheapo HEI as a substitute but it doesn't have one particular tuning feature I'm looking for. That being an adjustable mechanical advance limit.
As far as HEI's go, I've read and heard plenty of success stories as stand alone units. Then again, plenty of stories such as your own that have people pulling out their hair.
For the same reason as the ICMs burning up regularly is the same reason I'm hesitant to move to a fully programmable electronic distributor. MSD and the Progressive offerings all have a printed circuit board under the cap. That's a really tough environment for electronics to survive. There are also many stories about the MSD unit giving up after minimal service. There goes 500 bucks! Poof. Literally.
Here's one programmable distributor that's caught my interest. But I think there's a risk involved.
https://progressionignition.com/
Old Sep 10, 2023 | 06:12 PM
skinny z's Avatar
Old Sep 10, 2023 | 06:16 PM
skinny z's Avatar
Yep. Old school back in the day whiz bang technology!
That said, it's been as tough as nails. I heard the same isn't the case for more recently manufactured units. The again, what the hell is these days.
I better not have have jinxed myself with this praise for my old junk. I need it to work! Soon too.
Old Sep 10, 2023 | 06:43 PM
Welcome to my world.
The Progressive distributor sounds great "on paper", but I would be hesitant to use it unless the ignition coil was located outside of the distributor cap. Just my .
Old Sep 10, 2023 | 07:40 PM
vorteciroc's Avatar
Top Answer: 1
I was referring to the above statement...
And wondering as to what Tuning struggles were involved?
I personally find the MSD "Pro-Billet" Distributor very easy to work with the Mech. Advance, and very much LOVE the Limiting Bushing.
As far as the 6AL... it is just going to "Act" as the Set of Points and determine the Coil Dwell Timing and Multiple Ignition Strikes at lower Engine speeds.
It's the same thing as a HEI Module or ICM, but with a Rev-Limiter and Multi-Spark Discharge.
Coil Saturation is maximized for a given Engine Speed.
But doing so for one Cylinder is quite the task...
Unfortunately this Coil needs to deal with the speeds and demands of all 8 Cylinders.
That One Coil has to do a TON of very FAST work for all 8 Cylinders.
Comparing it to the easy job that a Coil on an LSx Engine would have...
IS A MASSIVE JOKE!
Old Sep 11, 2023 | 02:30 PM
skinny z's Avatar
It's more about product support than anything else.
Bluetooth connectivity only. No laptop interface possible.
And WHO are Progressive and will they be around in 10 years time when I need help?
Old Sep 11, 2023 | 02:34 PM
skinny z's Avatar
The only struggle Mr V is that leaning over the fender gets pretty old after a while.
The tuning is simple enough albeit tedious.
The mechanical curve wasn't too bad. I know where I'm going with that. It was the amount of effort I had to put in to dial in my vacuum advance. Lots and lots of back and forth with cause and effect and then further effect. More adjustments. But, I can say that sucker ran like it had EFI was it was all said and done.
Old Sep 11, 2023 | 04:03 PM
vorteciroc's Avatar
Top Answer: 1
Honestly, working under the Hood, leaning over the Fender or Radiator Support is murder on my body...
So I feel for ya!
Not enjoyable at all.
Old Sep 11, 2023 | 04:14 PM
skinny z's Avatar
So I feel for ya!
You should see some of the contortions I go through in a day's work. Being in industrial maintenance (as an electrician) for the last ten years has put me in some pretty bizarre situations. And I'm no youngster by any stretch.
My hobby shouldn't be the same!
Next up, crawling around on my back on a sheet of cardboard while I button up the bottom side of the old Camaro.
That is after I'm done leaning over the fenders doing the topside!
Thanks for listening....
Old Sep 12, 2023 | 06:25 PM
vorteciroc's Avatar
Top Answer: 1
I don't envy you having to handle Industrial Electrical work.
I used to get sent in to deal with some of the 3-Phase 480 Volt Equipment in the Lab/ Factory at GM.
Yeah... No thanks. Very happy to be avoiding those electrical issues now.
Abubaca
Jun 2, 2016 01:21 PM
formulating_88
Apr 30, 2014 11:49 AM
dhirocz
Nov 20, 2013 01:04 PM
TP355Z
Aug 27, 2007 05:57 PM
Abird4u2nv1
Nov 19, 2003 09:02 PM
