VATS is my last step. Please help, I know nothing
Old Oct 25, 2023 | 12:55 PM
dannyboyz28's Avatar
Hi there,
So I'm nearly getting this thing running.. beautiful 92 TPI. The only thing is vats because I don't have the stock ecm, but I have the original key.
I got a vats bypass module https://www.hawksmotorsports.com/gm-...-lt1-lsx-swap/ from hawks motorsports and I literally have no idea what I'm doing. I looked up the instructions but boy is this confusing.
Where do I install it? What wires are going where? I have no clue about wiring at all.
Alternatively, I watched this video:
and it seems easy with resistors. Should I just get these and make my life easier? https://www.ebay.com/itm/29596571312...Bk9SR5Skhv_sYg
Is there any other options for me?
Old Oct 25, 2023 | 01:52 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: VATS is my last step. Please help, I know nothing
If you don't have a stock ECM then there is no need to take steps to trick the ECM into thinking VATS is working, all you need to do is get the starter to crank, https://www.thirdgen.org/forums/elec...pass-vats.html
Old Oct 25, 2023 | 02:24 PM
Are you sure it has nothing to do with VATS? The original key with the chip supposedly would not match the ecu, right?
Then again, I checked the fuel pump, and the fuel pump is working (drained gas after plugging in ecu). ALSO, the security light turns off after about two seconds while it's cranking, but not starting. Crank sounds strong, so, you really think it's not VATS? That's what I've been told it is for so long because the "chip in the key doesn't match the ECU".
Could it be spark?
Old Oct 25, 2023 | 03:39 PM
OrangeBird's Avatar
Car: 1989 Firebird
Originally Posted by dannyboyz28
............ The only thing is vats because I don't have the stock ecm............
So, if ya want help, , , ya gotta help people to be able to help you by providing the answer to the $64000 question;
Exactly what ECM do you have in place of the stock one?
Little details can sometimes make huge differences...................
Old Oct 25, 2023 | 06:13 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Instructions are available here:
https://timers.shop/Documentation_ep_43.html
If finding a ground, splicing 12v power, splicing into the signal wire, and toggling the signal with the other two wires is too confusing for you, just pay somebody else for an hour of their time to get it done right.
Ughh61
Jan 3, 2007 02:00 AM
ls2twntur1200hp
Mar 28, 2006 09:58 AM
88-droptop
Sep 13, 2002 12:42 PM
Jazawin
Aug 17, 2002 10:27 PM
tpic1500
Jan 12, 2001 01:11 PM
