rattler 300 removal.
Old Apr 6, 2024 | 08:14 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
I just got a 87 iroc parts car. I noticed it had a rattler 300 installed under the dash. I plan to use the engine harness and dash harness in another Camaro. Is it possible to just remove the alarm system and return the wiring to factory design
Old Apr 6, 2024 | 08:24 PM
NoEmissions84TA's Avatar
Re: rattler 300 removal.
Anything installed after the car left the dealer can be removed.
The difficulty will depend on how much of a hack job was done during the installation.
Not familiar with Rattler 300, but most security systems only interrupt the starter cranking circuit by installing a relay.
Old Apr 6, 2024 | 08:34 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
I think it is a decent install job. I don't have the key and the steering wheel is damaged to. I will take some pictures in the morning. I haven't unloaded it yet. Black box with a antenna like wire and sets of wires from harness under drivers side of dash.
Old Apr 7, 2024 | 09:32 AM
Bobby Suth's Avatar
Axle/Gears: 273?277
Here are the pictures
Old Apr 7, 2024 | 08:16 PM
RATTLER 300 INSTALLATION MANUAL Pdf Download | ManualsLib
Old Apr 7, 2024 | 08:24 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
That took me to Google play store download. Didn't work for me. Thanks anyway
Old Apr 7, 2024 | 08:35 PM
vorteciroc's Avatar
Top Answer: 1
The Link worked for me.
Old Apr 7, 2024 | 08:50 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
I'm older than dirt. I do good posting on here! I also stay away from that type of stuff. Call me chicken if you want to. But really, thank you. I should be able to reverse what the installer did. If not. I will have my son download the link you provided
transaero
19
Dec 18, 2014 09:00 PM
hdis2002
Interior Parts Wanted
Aug 16, 2012 06:37 PM
kurfbird
May 10, 2007 01:07 AM
kurfbird
May 9, 2007 05:28 PM
