87 2.8 injector problem
Old Apr 12, 2024 | 11:15 PM
Austin87FB's Avatar
I have an 87 2.8L with an electrical problem. I’m assuming either bad injectors or bad ecm possibly. Injectors are not firing, I cheated a little and hardwired the fuel pump to the battery with my own inline fuse and switch to get it to turn on, is there any way I can cheat a little more with the injectors and be safe? I do intend to do a full engine harness replacement soon but I need it running for the next week. Previous owners chopped up the wiring on the firewall.
This is what I meant when I said it’s chopped up
Old Apr 12, 2024 | 11:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 87 2.8 injector problem
Is the ecm powered up ? Have you used a noid light on the injectors ? How do they ohm ? Has this car sat for a extended time?
Old Apr 12, 2024 | 11:53 PM
Austin87FB's Avatar
Im assuming the ECM has power because the idle air butterfly or whatever is next to the main butterfly, is opening on key turn but im not sure. the tags expired in 2013. i am more on the mechanical side and dont have much electrical experience, could you explain where / how to check with a noid light?
Old Apr 13, 2024 | 07:10 AM
OrangeBird's Avatar
Car: 1989 Firebird
Well then your answer is a simple one; If the previous owner "chopped up the wiring on the firewall" your gonna have to put all that back right if you want to hear it run. If that, for you, involves "I do intend to do a full engine harness replacement soon" then by all means you'd best get to it, cause there is no "cheat" that's gonna run the injectors without the ECM being properly connected.
PS, just curious, have you checked this fuse yet? (you'll get no injector pulse or fuel pump action if it's blown or missing)
Old Apr 13, 2024 | 07:35 AM
Engine: Lb9
Transmission: M20
a noid light gets hooked to a injector plug. You crank the engine and look for a pulse. If tags are that old more than likely the fuel system needs attention. Stuck injectors.
Old Apr 13, 2024 | 11:44 PM
Austin87FB's Avatar
Don’t worry, I’m changing the pedals.but under the dash isn’t any better
Ibrahim12..
May 5, 2023 09:02 PM
LiveIt!
Dec 16, 2017 01:06 AM
Duckman028
Nov 22, 2006 04:06 PM
Iroccer
Sep 27, 2003 11:22 PM
RBMZ28
Sep 2, 2001 03:10 PM
