Ignition wire
Old Jun 1, 2024 | 08:59 PM
Kmaro028's Avatar
Ignition wire
I'm trying to wire up a kill switch connected to my ignition does anyone know what wires I need to tap into?
Old Jun 2, 2024 | 08:34 PM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
Re: Ignition wire
vats car? if the yellow vats wires are not connected it's not starting
Old Jun 2, 2024 | 08:54 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Ignition wire
no vats in a 85 camaro
Old Jun 2, 2024 | 10:15 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: Ignition wire
The pink power wire that runs to the distributor ought to do it.
Old Jun 3, 2024 | 11:37 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Ignition wire
Disconnect your battery. Pull your shifter cover, look inside the center console for a big purple wire. Cut it. Install a toggle switch and pull it up so that it is accessible by popping out the ash tray.
Done.
Bobby_80s
Nov 14, 2025 06:45 PM
ace_012
Mar 26, 2011 02:58 PM
0pyders
Aug 29, 2010 08:14 PM
Bobby_80s
Dec 23, 2008 01:19 PM
85wilrocu
May 19, 2002 01:51 PM
