88’ GTA Fan on at Key on
Old Mar 5, 2025 | 05:31 PM
hessm70's Avatar
Engine: 355 TPI w/AFR 195s Dyno Don Headers
Axle/Gears: Borg Warner 9 Bolt, 3.27 gears
88’ GTA new 355 engine. LS fan assembly with stock wire harness. Not started engine yet but was doing an IAC cal. I go to key on and the drivers side fan is on. I put a new fan switch (goes between cylinders 6 & 8). Is it possible the new switch is bad causing it to ground causing fan to come on?
Old Mar 5, 2025 | 05:50 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: 88’ GTA Fan on at Key on
Fan switches come in normally open and normally closed flavors. You may have the opposite of what you need.
Old Mar 5, 2025 | 05:52 PM
hessm70's Avatar
Thanks Komet! I thought all were ground is on so let me check that.
Old Mar 5, 2025 | 05:57 PM
hessm70's Avatar
So switch is Summit SUM-8901117 supposed to be on at 185deg/ off 175.
ok unplugged switch, fan still runs so may be something else.
Old Mar 5, 2025 | 06:11 PM
hessm70's Avatar
@Tuned Performance thinks it may be in the a/c pressure switch setting so he’s checking the tune.
Old Mar 5, 2025 | 06:23 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Just checked, old tune and new tune have n/o fan switch selected. I’m wondering if the tune is bad on the chip or bad chip on the adapter.
Old Mar 5, 2025 | 07:30 PM
hessm70's Avatar
We’re still chasing this. So install just memcal and the fan does not come on. @Tuned Performance suggested reflashing start up tune so did that. Reinstalled and again fan on with key on.
Old Mar 6, 2025 | 06:49 AM
hessm70's Avatar
Update- I installed an old chip I had from @Tuned Performance and the fan did not come on at key on. @Reddragon88gta suggests its a Bin stacking issue so hopefully we can get it sorted. I want to get my new engine fired.
SketchyZed
Jan 19, 2018 07:26 PM
Newfie Iroc
Mar 6, 2015 07:17 PM
renemedrano842
May 14, 2010 10:02 PM
Jon88GTA
Jun 1, 2001 09:24 AM
