Wiper washer problem
Old Apr 20, 2025 | 08:10 PM
ars's Avatar
ars
Car: 1986 Chevrolet Camaro Sport Coupe
Engine: 6.0 LQ9, Truck Norris Cam
Transmission: 4L65E Z Pak clutches, Corvette Serv
I've been trying to figure out how to solve a problem with the washer signal. I tested the pink wire with the selector being turned to "mist" and get nothing when I measure the voltage from the wiper motor connector. However, I get a 12v when measuring it from inside the car on the connector above the steering column. It seems like it is passing through the fusebox, but I dont see any fuses that are blown nor a separate fuse for the washer motor. I'm thinking there is a break somewhere along its route, since I get nothing from the connector on the other side of the firewall. Should I just cut it and wire it directly to the connector of the wiper motor?
Update:
Sorry, was too quick to post. The wire was broken coming out of the c100 connector. Soldered it back and now it gets the 12v.
zeitghaist
May 5, 2020 12:13 PM
puttputt
Aug 13, 2016 04:12 PM
gholian
May 18, 2013 09:22 AM
BigBoi4Lyph
Sep 24, 2006 02:14 AM
Birmass
Jan 26, 2002 06:36 PM
