High Beams won't turn off!!!!
Old Mar 1, 2002 | 08:49 PM
86 Trans AM's Avatar
Ok I just installed a steering column I picked up from the junkyard. everything is fine except that my High beams do not turn off. Did I do something wrong? Did I forget to hook up a wire? Or is it the steering column? Thanks.
Old Mar 1, 2002 | 09:19 PM
2vmodular's Avatar
sounds like the rod that connects the top of the steering column to the dimmer switch has come out of alignment.
switch is towards the base of the steering column inside passenger compartment, has three wires running into it yellow, light green, and tan.
Old Mar 1, 2002 | 09:45 PM
Thanks alot man. I'll look into it tommorow. Thanks for the pics I really appreciate it.
Old Mar 2, 2002 | 06:52 PM
Chris Luongo's Avatar
I just bought my father a '91 Corsica, and the dimmer switch needed adjustment. It's near the topside of the column, and a little hard to get to. I simply dropped the column down (just the 2 big nuts there) for much better access.
1992CamaroGirl
Dec 25, 2017 08:45 PM
Derick15
Sep 17, 2016 05:28 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
BrianI
Aug 9, 2015 11:52 AM
