gages don't work!!!!!
Old Apr 7, 2002 | 11:22 AM
Ride4ME's Avatar
neither does my horn or h beams
help
Old Apr 7, 2002 | 12:50 PM
Rac'n 88 bird's Avatar
Hey Ride....
got a suggestion....may or may not help....
I had the same thing on my 88 Formula....even the same engine...check the connector on the Alternator...I know it seems odd...but all I did was clean a little corrosion out of mine and made sure the terminals connected and everything was o.k.!! hope it helps!
Old Apr 7, 2002 | 08:55 PM
breathment's Avatar
check ur fuses yet??
Old Apr 8, 2002 | 03:04 PM
Ride4ME's Avatar
Where is the alternator connection?
How can I tell if a fuse is blown?
Old Apr 8, 2002 | 03:23 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
the two wire plug on the alternator itself, right out in the open, spray some WD40 into the plug while its disconnected, and then reconnect it, also while you are at the alternator, check the condition of the bigger red feed wire on the backside of the alternator that is held on with threaded post and nut. make sure is not frayed or anything, mine were all frayed up bad and car had history of having battery going dead alot, no wonder.. all better now, never had that problem since ive owned the car, i fixed that the first day.. compare a new fuse to the current fuse and if the metal bridge inside of the fuse is not broken/melted- just as is the case with the new one- then it should be fine, if are in doubt about a current fuse, then replace it and try lights, etc then
good luck
Old Apr 8, 2002 | 06:55 PM
Hey guys....whats goin on?
anyways...yeah...thats what i had happening, too...no charging, no blinkers, no nothing....I thought I checked everything, until I decided to check that innocent looking alt. plug, and...BAMM...that did it...anyways...hope it helped and Im ready for a question anytime...cuz I got some of my own to ask..but theyre not imperrative right now!!
Old Apr 10, 2002 | 01:49 AM
Ride4ME's Avatar
well my lights work, my sounds, blinkers, tach,speedo,batt gage,
but it is only my oil, horn, h-beams, that don't work.
My gas gage "lies" to me. The needle will read 1/2 a tank,
then show 1/4?? Sometimes I think I have gas and I don't
I checked the alternator connections, they seemed fine.
I didin't check the fuse I have some higher numbered fuses
(15 to replace a 10) will this work okay??
Old Apr 10, 2002 | 04:20 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
correct amperage that you sre supposed to have for each circuit iwl be printed n white next to each fuse panel fuse slot, dunno why oil and fuel gauges are messed up, seems like third gen gauges are common problem area, i have repetitively pegged out temp and sticking tach at start up, so i guess no one can win.,,, must be crappy dash electrical design in these cars,. no one seems to have any idea what causes these instrument panel gremlins
good luck
Old Apr 13, 2002 | 01:49 PM
Ride4ME's Avatar
it reads 10 but I can't find any 10 replacement fuses
in the stores. Smallest I see is 15. Would that be okay??
Old Apr 13, 2002 | 01:59 PM
Ride4ME's Avatar
please help
Old Apr 16, 2002 | 09:08 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
personllay i owuknd hesitate to use 15 amp in it, also i would just rob a 10 out of a junk vehicle, i do that anyways every time i cut up a car or truck out here, so..., never have to buy new electrical switches or relays or breakers, etc etc
good luck,
1992rs/ss
Jan 31, 2025 05:10 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
TheExaminer
Aug 26, 2015 04:59 PM
Irocohio
Aug 12, 2015 08:03 AM
Fronzizzle
Aug 9, 2015 01:15 PM
