Will this work? Hope I dont kill my car!
Old Apr 9, 2002 | 09:02 PM
Nickerz's Avatar
Well for monthes my brakelights havent worked... Ive liked it LOL people get on my *** and they get the brake check of a lifetime, but... I finally got pulled over for it. So I finally got to fixen it. So
-Replaced rear bulbs
-Replaced fuse
nothing
-Replaced brake light switch (vacuum actuated type)
nothing
so today I tested the switch, with the botton out unpushed (as if you are breaking) both of the leads show current, hey its a good thing! and with the button pushed (if your pedal wasnt pushed) it shows current only on one side.
The tail lights come on, but the break lights dont. Im sick of dicken around so heres my solution.
Splice a wire from the second lead (the one that isnt always on, only when breaking) all the way back to the old wire attached to the breaking portion of the red taillight section. Cut the old wire and connect it to the new wire.
Will this be ok? Am I gonna kill anything?
-Nick
btw I dont know what im doing
Old Apr 11, 2002 | 06:15 PM
Nickerz's Avatar
I gotta fix this, prz help me guyz!
-Nick
Old Apr 16, 2002 | 09:04 PM
Nickerz's Avatar
DAMN!! this things been here at least a week. Can someone just give me there .02? Its suposed to be fixed but I have an extension. Someone help prz!
:hail: :lala:
Old Apr 17, 2002 | 12:59 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
This is something from another '80's GM car, but it should apply to yours.
the white wire from the brake switch goes through the turn signal switch in the column. Disconnect the turn signal switch under the column; slot "P" is the input from the white wire, "N" is for right rear, "M" is for left rear.
Jumper the white wire (when brakes are applied) to N or M. If you have brake lights, you need a turn signal switch on the column.
Matthew
Old Apr 17, 2002 | 08:24 PM
Nordbert's Avatar
If you know someone with a column out of a similar car, just
plug its turn signal switch plug into your car's harness. If the
problem goes away, then your turn signal switch is bad.
Old Apr 17, 2002 | 09:31 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
I know this a dumb question but I have to ask. When you put the new bulbs in, did you push them in and turn clockwise? I goofed on this, and it took me an hour to figure it out.
Old Apr 18, 2002 | 12:23 PM
Nickerz's Avatar
You think my original concocktion will work?
Old Apr 18, 2002 | 04:37 PM
jmd's Avatar
jmd
No. checking the switch like me and Nord suggested is the way to fly, man.
Terrell351
Jun 13, 2021 01:13 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Reborn756
Sep 4, 2015 03:42 AM
89-S-dime
Aug 12, 2015 11:57 AM
