TPI setup complete and more...
Old May 14, 2006 | 04:24 PM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Complete TPI setup from a 1992 Z28 with speed density wiring harness.
- Plenum (ported)
- Throttle Body (ported)
- Runners
- Intake Manifold
- Fuel Rails with 22lb injectors and regulator
They are all complete and have no damage, and are completely cleaned and were power washed after I took them off. The passenger runners has a few typical dings in it but not notiecable and can be taken out easily. Comes with wiring harness and most sensors, comes with almost new vaccum hoses.
- Water Pump w/pulley (rebuilt)
- Powersteering pump and new lines, works like new.
- A/C compressor, works very good blew very cold.
- Smog pump, dont know why anyone would want one but I have it.
- HEI distributor works good.
- Valve covers, excellent condition, except drivers side, paint is rubbing off.
- Leather pouches for Trans Am that hook to the passenger dash, one is black with gold and one is silver with black, both are in excellent condition. Black one seems to be brand new.
PM me for any pics or pricing.
Old May 16, 2006 | 12:34 PM
ALONZO_MANUEL's Avatar
Car: 1986 IROC-Z
how much for the harness?
Old May 16, 2006 | 02:11 PM
Drac0nic's Avatar
If you get to parting it out I need a plenum, runners, rails and regulator.
Old May 16, 2006 | 09:37 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Well... I did not originally plan on parting it out, because as a whole it is worth more. I have someone else who has been sending PMs to me, I havent heard from him in a day or so. So if he isnt interested anymore I will gladly sell you both the parts you want. As for harness, I have to think about it, because as I stated before I hadnt planned on parting it out. I will get back to both of you when I have some more info on the situation. THANK YOU
Old May 16, 2006 | 10:13 PM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
If you're interested in parting it out, I'd be interested in the injectors. Are they in good shape? Do they work, etc.? Have they been flow tested?
Old May 17, 2006 | 06:35 AM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
how much for whole any pics? tpi setup that is.
Old May 17, 2006 | 09:11 AM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Yes Iam interested in parting it out, there is someone who is sending PM's to me that is interested in the harness. Injectors were cleaned and flow tested 10k ago, they work perfectly and I havent had any problems with them, I had them cleaned and flow tested just to make sure. I have some pics of the complete setup, Iam at work right now and when I get home I will TRY to post them on here, Im not sure if it will work, if it doesnt give me your emails and I will send pics to anyone who wants them. As for the price of the injectors, I think I want like $60.00 shipped. Harness I want $100.00 shipped. TPI setup rails, runners, throttle body, plenum and intake manifold. The entire TPI setup is practically mint, it is super clean and the plenum and throttle body has been bored. The throttle body opening is about 100mm wide, just alittle bit bigger than stock. But pricing is ALWAYS negotiable.
Old May 17, 2006 | 08:24 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
PICS PICS PICS PICS !!!!!!!!!
Old May 18, 2006 | 09:10 AM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
TPI setup is SOLD. along with wiring harness and ECM.
BUT INJECTORS STILL UP FOR SALE !!
Also everything else is still for sale just not TPI setup.
Old May 18, 2006 | 03:43 PM
charris's Avatar
Car: 1978 C10
Engine: 355 TPI
Axle/Gears: 3:42
What is your price on the distributor?
Old May 18, 2006 | 05:49 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
PM sent
Old May 18, 2006 | 07:49 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
SOLD !!!!!
- TPI Setup SOLD !!!
- Injectors SOLD !!!
- Distributor SOLD !!!
- Ignition Module SOLD !!!
- Ignition Coil SOLD !!!
STILL UP FOR SALE
- Valve covers, excellent condition, drivers side paint is rubbing of alittle not bad at all.
Terrell351
Jun 13, 2021 01:13 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
KO1
Aug 31, 2015 06:31 PM
squiggy2
Aug 9, 2015 09:30 PM
