Alot of underhood stuff
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Master cylindar
A/C condensor
a/c controls
smog equipment, complete
sbc oil pan
sbc perimeter bolt stock style valve covers, no dings
sbc water pump, works
set of 74 casting heads. Off a 74 chevell with 400. Valve are larger, i believe 1.92, 1.5x. NOt sure on condition of heads, might need some machining. Complete with springs, retainers etc.
sbc 400 block for sale. Complete with heads listed above. Intake to oil pan. Motor sat in yard for a while and rusted a bit in cyl walls, im sure it can be broke loose and honed out and be fine.
700r4 for sale. Not sure on condition, but it ran when motor was pulled, no torque converter, pickup only
84 z28 suspension parts, let me know what you need
2.73 open diff
if you need anything else, let me know.
A/C condensor
a/c controls
sbc oil pan
2.73 open diff
If the price is right, I will sell it. I'm located in western NC
The block is dissasembled. The heads have a small crack inbetween the 2 combustion chambers, nothing a machine shop can't fix. They are larger valves, not smog truck valves. The pistons looked fine, main, rod bearings are ok, worn, but very smooth. The cam didn't have any wiped lobes. There was some buildup in the cyl walls, but they are going to be honed out. If someone wants, for a few extra bucks I can throw some 305 heads on there to bump the compression to 10.5:1 from 8.5:1.
The engine is complete with a stock dual/plane intake to the oil pan. All bolts and assorted pieces come with it if you like.
Car: 2001 GMC 2500HD + 84 Z28 Project
Engine: 305 for now-not running/going 4 383
Axle/Gears: Unsure-yet
ac parts
I need all the underhood a/c parts. What do you have and how much?
I have everything, Condensor, Evaporator, canister, lines.
Located in western NC
Still have a bunch of stuff.
I now have assembled 305 heads 58cc chambers 1.9x, 1.5x valves, great condition.
882 400 sbc heads 76cc chambers, 1.9x, 1.5 valves. Came off of a 74 chevelle.
Complete 305, was running when it come out of the car.
Radiator, good shape
Brake booster and master cylindar.
Need this stuff gone. Ill take any reasonable offers.
LT1Formula
Oct 8, 2015 08:34 PM
