SD intake, runners, VATS bypass, & ECM
Old Aug 3, 2006 | 10:39 PM
sauer_power's Avatar
Car: 82 Firebird SE
I have an intake base off of a 91 firebird, with runners but one has hole that was filled in with JB weld. also have the ECM out of that car and a brand new Painless Wiring VATS bypass. Im open for offers this stuff is doing me no good sitting under the bench.
Old Aug 3, 2006 | 10:53 PM
koolctk's Avatar
Car: 1989 Trans Am GTA
do you have a plenum at all for SD, i have a 92 bird with a v6 and am considering buildng a motor from scratch, maybe anything else you have that i could use.
Old Aug 4, 2006 | 12:29 PM
Car: 82 Firebird SE
I do and also have a TB but Im not sure if Im using that in my project or not
Old Aug 15, 2006 | 02:46 AM
The_Beast's Avatar
Car: 91 rs
Engine: 5.7 350 :))
Transmission: 700 r4
Axle/Gears: 1996 - 3.42
Is the JB weld holding the runner to the manifold?
Old Aug 15, 2006 | 12:39 PM
Car: 82 Firebird SE
No there is a hole in one of the tubes were something fell on the motor when it sat in my shop, and my dad filled it in with JB weld so it didnt look as bad. I was planing on running them until I got an aftermarket set but I was given another stock set from a friend who bought some Edelbrock runners.
Old Aug 15, 2006 | 02:04 PM
The_Beast's Avatar
Car: 91 rs
Engine: 5.7 350 :))
Ohh ok. Well you have a pm then.
Old Aug 15, 2006 | 07:58 PM
Lucas 89L98's Avatar
Car: 89 IROC
Engine: sb400
How much for the 730 ecu? It is a 730 correct?
Old Aug 15, 2006 | 08:20 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Talk to me about the VATS bypass...how's that work? Might be interested.
Old Aug 15, 2006 | 08:47 PM
Car: 82 Firebird SE
Its a painless model it has 3 wires one for power one for ground and a signal that goes to the ecm its for installing the stock harness and ecm where you dont have the stock VATS system in. it install right by the computer under the dash.
Old Aug 15, 2006 | 10:30 PM
Bull's Avatar
Engine: LT1; None
Ok, so is it a way for me to eliminate VATS on my stock '92 Formula? Or is it for people who have electronics swaps?
Old Aug 16, 2006 | 01:15 PM
Car: 82 Firebird SE
it could be used for either job. I got it for m my 82 firebird that i put a 91 SD setup in, since the 82 didnt have vats i needed to by pass it.
Old Aug 16, 2006 | 02:38 PM
Bull's Avatar
Engine: LT1; None
Any chance you could give me a pic of the part, either on the bench or installed in your car?
Any idea on how much you want?
stalkier
Dec 6, 2015 11:25 PM
hydrolic144
Oct 4, 2015 08:23 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
djmarch
Aug 9, 2015 05:27 PM
