Proform electric water pump
Old Sep 13, 2006 | 06:46 PM
FullSendRacing's Avatar
Car: '85 Trans Am FAILBIRD
Axle/Gears: 4th gen torsen 3.42
Proform electric water pump - SOLD
This water pump was installed in my firebird and used 15-20 hours. Has some nicks in the red anodize but otherwise in great shape. Please pardon my dusty work shop - the black part of the pump has no scratches or anything - it's just the picture.
$110 shipped
SOLD
Attached Thumbnails Proform electric water pump-img_1888.jpg   Proform electric water pump-img_1889.jpg
Old Sep 13, 2006 | 06:53 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Is that a distributer I see chopped in half LOL good luck with the sell.
Old Sep 13, 2006 | 08:35 PM
LOL! yea! had to prime the oil pump before firing up the camaro - and the shaft I bought didn't have the collar to hold back the oil pressure in the distrib hole.... so I "fixed" it
Old Sep 14, 2006 | 09:34 AM
ONEFASTZ's Avatar
Car: 1986 CAMARO
Engine: 434
Transmission: th400 rmvb,nc 4500 stall
Axle/Gears: MOSER 12BOLT,35splineaxels,4.33gear
do u have the part number for the water pump?
why did u take it off, did u not like it?
Old Sep 14, 2006 | 09:44 AM
Jegs' part number for this pump is 778-66225R
On the contrary, it's awesome having an electric pump! I had it set up so the pump and electric fan would both run even after I shut off the car. That way the engine was always cooled down properly. You can also throw a switch on it or something like that so if you're a drag-racer you can run the cooling system during staging without running the car.
If you frequently look at the 'parts for sale' forum you'll see an aweful lot of stuff I'm selling - unfortunately I have a project car that's coming apart and I was only able to use some of it on the new project. I *really* hate selling off stuff for less than I spent on it only a year ago but it's also a shame to have a ton of almost-new parts sitting around the garage collecting dust.
Old Sep 14, 2006 | 09:53 AM
ONEFASTZ's Avatar
Car: 1986 CAMARO
Engine: 434
ok ill get back to u
Old Sep 15, 2006 | 02:12 PM
Monster Zero's Avatar
Car: 1991 Camaro Z28
Does this allow you to still use the stock Serp drive? or do you need to change something around?
Old Sep 15, 2006 | 02:15 PM
you will have to make changes. with a stock serp setup you have a reverse flow water pump and it's one of the main pulleys in the system. When I was running this pump I had just PS and an alternator, so I just ran a V-belt setup. If you're clever you might find an alternate routing that works but I'm not sure.
Old Sep 15, 2006 | 03:42 PM
izcain's Avatar
Engine: 584
They sell simple to install kits for the thirdgen that can mount the alternator and power steering pump low and is driven from the crank only. Saves even more in rotational mass .
Old Jan 31, 2007 | 11:19 AM
water pump is still for sale
Old Feb 14, 2007 | 10:46 AM
SOLD
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
