comp hydraulic roller cam. xr 282-10
Old Feb 28, 2007 | 06:35 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
for sale is a slightly used (500 miles) comp cam. xr 282-10 model.
230/236 duration @ .050" and .510/.520 lift with 1.5 rockers and .545/.554 lift with 1.6 rockers. 110 lsa. This one is special because its on a small base circle which means it will work in a stroker motor no problem.
150 shipped please.
Old Feb 28, 2007 | 10:31 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
to bad i just ordered mine...
Old Mar 6, 2007 | 08:40 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
id like to buy this but do i have to do anything to the stock heads or can i just install the 981 springs? going in a 305
Old Mar 6, 2007 | 11:39 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
What is the comp Part number? (Should be stamped on the end of the cam.) Is there any damage or wear in either the lobes, journals or distributor gear?
What about the lifters?
Old Mar 7, 2007 | 09:56 AM
Car: 1979 Malibu
Engine: Blown LSx
this cam is too big for stock heads, you need either 986 or 987 springs 981 are to weak, cam is also WAY to big for a 305 with stock heads, the heads will not allow the cam to work to it full potential, to make power your xcam heads and intake need to be matched. id look for something around .470 or .480 lift
Old Mar 26, 2007 | 09:33 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Re: comp hydraulic roller cam. xr 282-10
Is this cam still available?
Old Mar 27, 2007 | 04:27 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Consider it sold
Old Mar 27, 2007 | 07:04 PM
GonnabeatargetZ's Avatar
Car: 86 SC Camaro drag car
Engine: 406
Transmission: Th350
Axle/Gears: 8.5 10 bolt 4.10
I used this same cam in a relatively stock 350 short block w/ Iron Eagles Damn thing idled sane at 750 RPM and ran 11.80s all day long! GREAT CAM
Old Mar 28, 2007 | 07:43 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
paypal payment sent
no green
Jan 9, 2016 09:22 PM
KO1
16
Oct 15, 2015 05:00 PM
