Comp Cams XE256 Complete Cam Kit. Brand New!
Car: 86 Camaro IROC-Z
Engine: 305 LB9
Hi, I have a Comp cams XE256 extreme energy Hyd flat tappet cam kit for sale. This cam has never been used and in original box. Im asking $350 shipped anywhere in the lower 48.
The specs are:
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,200-5,200
Intake Duration at 050 inch Lift: 212
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 212 int./218 exh.
Advertised Intake Duration: 256
Advertised Exhaust Duration: 268
Advertised Duration: 256 int./268 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.449 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.456 in.
Valve Lift with Factory Rocker Arm Ratio: 0.449 int./0.456 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
This kit includes: Camshaft, Lifters, Timing Chain set, Valve springs, VS retainers, Valve locks, Valve stem seals, and lube.
Heres a link if you want more info: Cam Link on Summit
The specs are:
Engine: 305 LB9
Re: Comp Cams XE256 Complete Cam Kit. Brand New!
Anyone? Summit has it listed as a 87-98 but this will also work with pre-87 SBCs. This is a good cam for a 305 TPI set up to replace the peanut cams.
Engine: 305 LB9
Engine: 305 LB9
ZOOOOOOOOOOOOOOOOOOOOOM to the topppppppppppppppppppppp! Hey How about you makes me some offerz??!11
Car: 1986 Trans Am
Axle/Gears: 3.23 gears
hi,
I'm about to build-up my old 305 and this would be a good component.
You are selling the kit, yes... pn PART #K12-256-4?
thanks,
Andrew
thanks,
Andrew
Engine: 305 LB9
Hello. Yep its the complete cam kit, everything in that link/picture on summit is included with this kit. And I can make you a deal if youre interested.
Terrell351
Jun 13, 2021 01:13 PM
ambainb
Apr 25, 2016 09:21 PM
