going different direction, all must go
Old May 25, 2007 | 11:06 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
ok, i have decided to scrap my current plan for the plan I wanted to do in the first place with the old car, SOOOO... I have a shitload of stuff for sale
All engine parts have less than 100 miles on them, and most others are very low and ill specify
406 shortblock .030, cast 15cc dish pistons, arp bolts, no cam or timing stuff just block and rotating assy. will need a pump and bearings
3931509 block 2 bolt casting $450
Dart Pro- 1 Alum cylinder heads 200 cc 2.02 1.6 manley race flo valves Have been lightly ported, short side radius cleaned up, flow 264 cfm @ .600 lift, have comp 918 beehive springs, comp retainers, guideplates.
are complete. Gasket matched to a 1205 gasket
have over 1600 in them, will take $1200 complete for both, bolt on ready
comp cam extreme energy retrofit roller cam XE294 cam .242/.248@.050/ .540/.562 on a 110 $240
comp cams retrofit roller lifters $125
comp cams timing cover with reinforced plate for cam button, powdercoated black $90
comp cams chromeoly one piece pushrods 7.300 Length $80
sbc roller tip rockers 1.5 ratio $100
MSD Pro-Billet Distributor 8361 pn, with cap and rotor, vacuum advance $175
Msd Blaster 2 Coil like new $40
MSD 6-AL, also like new cond. $160
Edelbrock CNC ported Vic Jr intake, has maybe 20 miles on it $175
Hooker Ceramic 1 3/4 Longtubes, have a small scrape on the bottom, and a few scratches but 100 miles on them 2210 part number $475
GMPP Cast alum Tall valve covers say "chevrolet" have been drilled for breather holes and oil fill, come with k&n breather elements $200
750 Barry Grant Mighty Demon Carb mechanical secondaries, no choke horn $300
Centerforce externally balanced Manual Flywheel for 400 $225 500 miles max, light surface rust on back side. NONE ON SURFACE
1995 t56 6speed setup from lt1 car spec stage 3 clutch, new gm hydraulics, spohn crossmember for 3rd gen camaro (might keep) comes complete with bellhousing and shifter $2000 bolt in ready in a 3rd or 4th gen camaro will separate if i find buyers for all the parts. this price is negotiable alot because of the different applications.
All parts are in EXCEPTIONAL to almost as new as they can get condtion, if you know anybody looking for this stuff also, please help a brother out. I am doing this to fund the new beast, and the way i shouldve done it the first time. Im sure i will have to edit as im sure i forgot a couple of things along the way
any questions feel free to pm or call 317-777-1569 everything located in martinsville in area, subject to shipping charges
Old May 26, 2007 | 07:36 AM
myz06's Avatar
Car: 87 IROC
Engine: 406
Transmission: th350
Axle/Gears: 10 bolt 3.73
Re: going different direction, all must go
How's $475 shipped to KY (42001) for the long tubes?
Old May 27, 2007 | 02:19 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Got the advance springs and parts that come new with it?
Old May 27, 2007 | 10:51 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
ill pass on that, depending on how far you are away from indianapolis, i would meet for a small fee though
im sure i do
Old May 27, 2007 | 03:52 PM
myz06's Avatar
Car: 87 IROC
Engine: 406
Transmission: th350
Can you post up some pics of the longtubes or e-mail to restinhi@comcast.net Thanks
Old May 27, 2007 | 10:32 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
they are still in the car but let me go get some tomorrow... ill email them to you
Old May 27, 2007 | 11:31 PM
Pm gm's Avatar
Hi can i get pics of GMPP valve covers and msd (6al)box sent to pmccall@adelphia.net thanks..
Old May 28, 2007 | 08:05 AM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
500 shipped for the headers? assuming the pics turn out okay.....
Old May 28, 2007 | 06:02 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
what are the specs on the lifters and do u have any pics of em
Old May 29, 2007 | 09:12 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
Old May 29, 2007 | 09:14 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
and more
Old May 29, 2007 | 09:16 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I'm lining up next for the lifters also. Let me know if the condition...ie..miles, general condition, history, etc....
Let me know if they become available.
Old May 29, 2007 | 09:17 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
525 maybe shipped if you want to go with that
pics of the covers are up, and ill snap a couple of the box... its in brand new condition though... all of these parts have less than probably 100 miles on them
Old May 29, 2007 | 09:22 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
they are probably less than a few thousand, and they work just fine all rollers are in great shape
they are available to whoever jumps
Old May 29, 2007 | 05:45 PM
any part number for the lifters??
Old May 30, 2007 | 08:19 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
not till i get them back out... they are comp retros with the link on them
Old May 30, 2007 | 08:28 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
to the masses, these prices are negotiable a tad, please keep the lowballing to yourself though
Old May 30, 2007 | 09:01 AM
wesilva's Avatar
Transmission: 200R4
If they are still available, I can send you money via PayPal ASAP. Let me know.
Would $125 shipped to 87108 work for you?
Old May 30, 2007 | 12:57 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
i have an offer on the table for 125 and hes gonna pick them up, but ill let you know
Old May 30, 2007 | 01:19 PM
wesilva's Avatar
Transmission: 200R4
Thanks.
Old May 30, 2007 | 09:59 PM
i take it the lifters are considered sold? i just needed a part number to make sure i could use them but if they are already sold to another person after i asked about em thats fine.
Old May 30, 2007 | 11:04 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
actually i got a pm from the potential buyer as soon as i put this ad up... and he is local, if it falls through, i will certainly get you that number when i yank the intake back off and pull the cam/lifters
Old May 31, 2007 | 06:31 AM
i appreciate it keep me posted
Old May 31, 2007 | 10:03 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
everything but the trans setup is spoken for until further notice... thanks for looking
Old Jun 26, 2007 | 08:36 AM
budofbama31313's Avatar
Car: 91Z, 97RS, 99Z, 02Z
Engine: TPI 383 Vortec, 3800, LS1, LS1
Transmission: T56, 700R4, T56, 4L60E
Axle/Gears: 3.73, 3.43, 3.42, ?.??
How much for the flywheel, clutch setup, hydraulics, and cross member plus shipping to 36870 or 71446? I basicly got ripped by a junkyard and now trying to get all the other parts needed.
Old Jun 26, 2007 | 08:45 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
i will check to see if the trans is for sure sold or not today and get back with you
Old Jun 26, 2007 | 05:51 PM
pr0zac's Avatar
Car: 1991 z28
Engine: forged 385 with afr's
Transmission: built 700r4
Axle/Gears: 9" and 4.56
i am also interested in the flywheel and clutch
Old Jun 27, 2007 | 07:50 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
check your pms, im the guy whos interested in your 9"
Old Jul 2, 2007 | 11:32 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
clutch-400
flywheel-225
hydraulics-100
x member-100
if interested in all i will ship for free
Old Jul 2, 2007 | 11:44 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
i put prices up there, still havent heard anything back from you but we could work something out on that 9" if you wanted to
let me know
Old Aug 12, 2007 | 12:50 PM
MemoryRacing's Avatar
Car: 85 Z28
Engine: 5.7
Axle/Gears: 4.11 10 bolt
Headers still available? or did they sell?
Old Aug 12, 2007 | 01:04 PM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
Can you please PM me all you know about the 406 short block. I am VERY interested, and I am in Jackson MI and could pick up within a few weeks if I decide I want it since your only about 4 hours away
Old Aug 13, 2007 | 08:50 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
everything from this setup is gone... thanks for looking
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
gixxer92
May 18, 2017 11:20 AM
efiguy
Sep 27, 2015 01:30 PM
Lmancha96
Sep 25, 2015 08:11 PM
