some rare and high perf. parts for sale.
Car: 1987 Iroc-z Convertible
some rare convertible and high perf. parts for sale.
NEW Camaro center console Upper plastic. (I bought it and mounted my hurst dual gate shift plate to it and cut out the window switches but never installed it. the remote hatch release is not cut out. $50
or I have a used one in near perfect shape for $30
stock radiator from my 87 no leaks $50
Stock reman cast iron long water pump standard rotation(87 and prior). never used but installed and has been bolted to motor for around a year but stored inside. $25
NEW GM Camaro side dash (heat a/c)vents these are new in box. I have the upper and lower side vents. $30 for all 4
87 Iroc convertible trim piece on the top above the windsheild. has a crack where the handles are but not noticable when installed. $75
dash shell from an 87 camaro no pad, gauges, etc. This is from my 87 vert so it has the holes where the comm pouch goes but you could install the plain firebird (plain black, no screen printing.) into and have somewhere to store maps or whatever. $20
Non CC GM distributor rebuilt with Pertronix Flame Thrower kit. Never used after rebuilt. It is kit # D8001 from summit. the kit was $120 itself and it is already done. $100
complete brackets and pulleys from an 87 camaro. $50
semi polished alternator from an 87 stock alt case and I started to polish front plate is done but the rest could use a little more. $40
stock 400 crank and rods (resized with ARP bolts) and new speed-pro hyper pistons. These are currently in a motor I was building but I changed my mind they have never been ran since machine shop. $350
700r4 with Lokar kick down cable and dipstick. $300
milodon stock replacement oil pan installed but never finsihed the motor a few scratches. $50
87 Iroc hood with mint louvers $150
power steering pump and brackets and lines $50
I can get pics of all the motor and tranny stuff is still in the car so I will need a little time to take it out. all prices are plus shipping.
Re: some rare and high perf. parts for sale.
I am kinda holding off for right now. I might buy another camaro next year. If I do I will let you know.
