Complete TPI Intake,Rails,Injectors,Throttle Body,ECM,Harness,Bolts,Gaskets,Sensors
Old Sep 22, 2007 | 08:14 PM
Stevo's Avatar
Car: Pair of 92 Z28s
I have for sale here a complete TPI setup from my 1992 Z28 Camaro. All the parts have been cleaned up and painted. Not a show winning paint job but it looks good. No problems with anything, no stripped bolt holes, everything here is ready to go. All mating surfaces and thread holes were taped up before painting and everything is loosely bolted together for shipping. I suggest you tighten everything, sensors and air fittings are only hand tight.
Included:
-Stock Manifold
-Stock Plenum
-Stock Throttle Body
-TPIS Airfoil
-SLP Runners
-AFPR, i believe its made by TPIS but im not sure
-Stock 22lb Injectors
-New Gaskets
-Bolts
-Thermostat Housing
-ECM
-Harness
-All sensors are there, TPS Sensor is 1 year old.
What you need or will need to do:
-2 Long intake runner bolts are missing, never noticed or had a problem until i disassembled everything.
-Distributor Clamp/Hold Down.
-Fuel Pressure will need to be set, im not sure where its set now
-9th Injector Hole has a plug that will need to be RTV-ed back in, it was removed to paint or it can be left out and used.
The Engine harness has not been hacked or cut except the O2 sensor wire has no connector on it.
Any questions or comments dont hesitate to ask, ill do my best to answer them.
I would like to get $450 Shipped, that includes everything mentioned above. Id like to keep this all together for someone looking to do the swap. If no interest in the next couple of weeks i will consider parting this out or it will go to ebay. Price is set and i think it is a good price for what your getting.
Nothing to hide here, i have done buiness with many people on this board and im sure they would vouch for me if i asked.
Package will be Insured, and tracking # will be provided.
Thanks!
-Steve
Pictures:
Old Sep 23, 2007 | 01:24 PM
camaroz2810's Avatar
Car: 1987 Camaro Z28 IROC
Re: Complete TPI Intake,Rails,Injectors,Throttle Body,ECM,Harness,Bolts,Gaskets,Senso
if you decide to break this stuff up, I call the SLP runners.
Old Sep 23, 2007 | 06:52 PM
Stevo's Avatar
Ill let you know.
Bump, post meant to say $450 shipped forgot to change it yesterday.
Old Sep 23, 2007 | 08:19 PM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
I'm thinkin hard on this one, will it work on a 92 305?
I'm old school and know nothing about these! Not afraid of the mechanical side though, rebuilt plenty of engines in my time.
Old Sep 23, 2007 | 08:35 PM
Stevo's Avatar
Yes it will work on your motor, you will have to just get these fuel lines to match up to your current lines. I forgot to post but i can include the flexible rubber lines that attach to the hardlines. This may just be a simple plug in, im not sure if anything is different about TBI fuel lines in the engine bay.
Other then that, swap the fuel pump and you should be good to go. Pretty sure a TBI fuel pump cant supply enough pressure. Im supplying a complete harness with ECM.
Old Sep 25, 2007 | 06:38 PM
Stevo's Avatar
Bump.
Old Sep 26, 2007 | 01:24 AM
zz28jgallo's Avatar
if you end up selling plenum by itself i think iam first in line
Old Sep 26, 2007 | 07:45 PM
Stevo's Avatar
$425 Shipped....
This is a good price for what i am selling. Have any questions, need anymore pictures...just ask.
Old Sep 28, 2007 | 08:16 PM
Stevo's Avatar
Bump.
Old Sep 30, 2007 | 07:39 PM
Stevo's Avatar
Bump.
I am including the rubber flex fuel lines and also the distributor hold down clamp.
$425 Shipped.
Old Oct 15, 2007 | 08:17 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
PM sent
Old Oct 15, 2007 | 09:21 PM
Stevo's Avatar
Sorry everything has been sold.
Old Oct 15, 2007 | 10:05 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
if by some chance the buyer didn't take or want the 9th injector plug/bung, I need one!
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
justin57
Aug 20, 2015 07:05 PM
squiggy2
Aug 9, 2015 09:30 PM
