1988 L98 IROC Engine Parts
Hey everyone,
I have a bunch of parts from my project 1988 IROC-Z 5.7 Auto that must go. The list of engine/drivetrain parts appears below; I also have some interior parts that I am posting in the other forum. All parts were removed when the car had approximately 85K miles on it.
-Stock shifter
-Stock computer w/Hypertech chip
-Jegster torque arm
-Stock torque arm
-Stock crankshaft
-Misc stock transmission parts (crossmember etc.) / some pieces from Hurst TH400 conversion
-Stock oil pan
-Stock factory oil cooler system
-Stock water pump
-Stock front brakes
-Stock mass air flow sensor (modified for high flow)
-Stock A/C system (most system components)
-Stock cruise control system
-Stock flexplate
-Misc. pulleys
-Stock throttle body boot
-Stock upper radiator cover
-Stock replacement radiator (NOT aluminum)
-Stock & ACCEL coils
-Stock lifters/pushrods
-Stock harmonic damper
-Stock timing chain
Let me know and thanks!
-Stock shifter
-Jegster torque arm
-Stock torque arm
-Stock crankshaft
-Stock oil pan
-Stock water pump
-Stock front brakes
-Stock flexplate
-Misc. pulleys
-Stock timing chain
Re: 1988 L98 IROC Engine Parts
MAF $50. Where is the part number on the unit? Let me know and I will check it out. (Will be gone to LSX Shootout until next Wed, will get back with you thereafter).
$100 for both.
$175. It's the non-adjustable one BTW.
Yup, it'll fit whatever, because it bolts to the underside of the body (has its own in-tunnel "crossmember" that fits along the ceiling).
$100 for both.
Last edited by WernerGMHTP; Oct 8, 2007 at 08:23 PM. Reason: Automerged Doublepost
Car: 1989 Iroc-Z
Engine: 383 FFI
Transmission: TKO600
you wouldn't happen to have any injectors lying around would you? I didn't see them on your listn but im looking for some and don't feel like buying new ones
I have stock LS1 injectors, which would fit but I am pretty sure are not the correct pount size you'd be looking for...
mustangman65_79
Aug 11, 2015 03:17 PM
