F/S 416 Heads, mini starter, XE268H cam, 2101 Intake, Distributor, +More
Car: 99 Mystic Green Trans am
Engine: LS1: Heads, MS4 cam, bolt'ons
Transmission: Fully built T-56 w/Spec3 & Pro 5.0
All right guys I've committed to my LS1 swap in my FB so it is time to let lose some of my parts.
I will do paypal but 3% fee applies for the smaller things. Anyone may PM me or drop me a line at jnreilly@sbcglobal.net.
Let me know guys, all work with ya
JR
416 heads with 3 angle valve job and gasket matched.
mild down a little for some more compression.
Exhaust port valves changed with stock size Manly valves.
Also heads now have bolt in APR rocker arm studs
Done by a reputable shop that races their cars in all the
competitions down here.
Comes with shop's brand of Springs and retainers good for .500 lift
maybe .550 lift I'm not sure. I was running .477''/.480'' without a problem.
2000miles since wprk. - $400 shipped
JR
Re: F/S 416 Heads, mini starter, XE268H cam, 2101 Intake, Distributor, +More
Comp Cam Xtreme Energy XE268H Hydraulic Flat Tappet Camshaft
Lift: .477''/.480'' Duration: 268°/280° RPM Range: 1600-5800
Makes a 305 sound GOOD! Lifters included and were kept in order.
750 miles on parts. - $110 shipped
sbc/lt1 mini starter in exelent shape $55 shipped
Flowmaster y pipe two 2.5" inlets 3" outlet - $23 shipped
2101 Ebelbrock Intake with new polished coolant neck. - $65 shipped
Mallory Unilite distributor with wires and spark plugs and accel coil.
Set-up worked and works great.
- $145 shipped
- $145 shipped
(above picture) Edelbrock hard fuel rail with Jegs fuel filter and stainless line to mechanical fuel pump. - $40 shipped
Perma-Cool Hi-Performance Stainless Steel Flex Fan 15". - $25 shipped
Granny's plastic mech fan - $15 shipped
Used Mr. Gasket Street Scoop 2.
The aluminum intake mount has been shaved down 1"
to make it closer to the hood. - $150 shipped
Width: Front - 12-3/4'', Back - 7''
Overall Length: 14-1/2''
Fits: 5-1/8'' Necks
Fits: 5-1/8'' Necks
A/C delete Pulley - 45 shipped
I have one 180 stat and one 160 state both Milodon High-Flow Thermostats both slightly used. - $12 shipped each
1405 Edelbrock Carb that need service, never got it working 100% right
Even after rebuilding it myself. But it could very well be my inexperience with crabs. comes with jet vacuum springs. - $55 shipped
that's it for engine stuff, for looking.
bump for today.
TTT for today
TTT for Today
Car: 1985 Trans Am
Engine: plain ol' 3-0-5...for now LoL
Transmission: aUTo
I know this was posted last month but do you still have any of this stuff... well, the starter?
Car: '84 Camaro
Engine: 5.3l TSP 224r
Transmission: TH350 3600 stall
Axle/Gears: LS1 3.23
Let me know if you still have the cam
mhatfield 14
10-24-2015 07:48 AM
