ET Drag, stealth intake manifold, starters, radiator, driveshaft, edelbrock waterpump
Car: 1984 z28
Engine: BBC
Transmission: TH400
28x10.5/15 stiff wall ET drag, 70-80% life left - $100
82-92 radiator, used for 50 miles, lifetime warranty from autozone - $40
Mark William 3" chromoly driveshaft center tube, no yokes or end pieces, about 48" long - $30
Weiand Stealth sbc intake manifold - one thermostat bolt stripped out - 100 miles on it - $30
Edlebrock aluminum long water pump, with pulley and arp bolts, 30 miles - $45
Mini starter sbc staggered bolt pattern - 3000 miles - $30
Standard sbc starter straight bolt pattern - 300 miles - $30
MORE PARTS!!!
Holley blue fuel pump - $30
Distributor with proform 50k volt coil kit - $35
30% reduction crank pulley short water pump aluminum - $20
MORE PARTS!!!
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Re: ET Drag, stealth intake manifold, starters, radiator, driveshaft, edelbrock water
i'm VERY interested in the mini starter(LT hedder swap coming up), what advantage does the staggered bolt pattern have? what brand starter is it? how much to ship to 80234? what kind of payment you want/accept, paypal would be nice.
Car: 1984 z28
Engine: BBC
Transmission: TH400
no advantage/disadvantage, just the mounting holes. Dunno the brand, shipping is like $18, and paypal is fine.
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
post pics of tires and driveshaft or send pics to all4u@hot-shot.com
I can drive to you and pic it up. I'm in oakbrook.
Car: 1984 z28
Engine: BBC
Transmission: TH400
Mark Wiliams sticker still on the shaft
how much life is left
mini starter
mini starter
Last edited by scorchmaster; Jan 13, 2008 at 02:41 PM. Reason: Automerged Doublepost
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Interested in the water pump if it will work on a 1990 L98. Do you have a part # for it? Could you post a pic of it?
Thanks.
Thanks.
send me a PM with your info for paypal so I can make the transfer.
Car: 1984 z28
Engine: BBC
Transmission: TH400
I guess it'll work with a new pulley, mine is for a v belt u need a serpentine one.
Car: 1984 z28
Engine: BBC
Transmission: TH400
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Car: 1984 z28
Engine: BBC
Transmission: TH400
mildly bad, I tried to fix it and it held for a little until I switched the thermostat out again.
Car: 1984 z28
Engine: BBC
Transmission: TH400
if you look, it's the holes that looks like it's filled with black stuff, the other one has a stud. If you helicoil it and epoxy the helicoil in place it should hold
mini starter is gone
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
That water pump won't work for a serpentine belt setup since it was for a v belt. The v belt spins the water pump clockwise and the serpentine spins counter clockwise. Just FYI and ttt for ya.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Offset holes are for large 14" 168 tooth flexplate / flywheel.
12 1/2 153 tooth starter is inline.
On the later blocks GM only drilled holes for one type starter/ flywheel combo whereas the early blocks had all three holes drilled and tapped.
Car: 85 TA
Axle/Gears: 10 bolt
Still have the intake? I need one as I just cracked mine.
Car: 85 TA
Axle/Gears: 10 bolt
I am going to look at one tonight, but if that doesn't work I'll be in contact with you about getting this one.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
water pump still available?
Car: 88 Monte Carlo LS
Transmission: 200R4
Is the distributer in good shape. How much to ship to farley Ia 52046.
Mike
Mike
Car: 1984 z28
Engine: BBC
Transmission: TH400
Worked amazing on my car, I just switched to a MSD distrib. Shipping is about $18.
Car: 1980 Chevy Stepside
Engine: 5.7L 350
Transmission: TH350
Axle/Gears: 3.73 L-Slip
can i get some pics of the holley fuel pump please sir, and thank you
Car: 91 camaro RS
Engine: 350, forged 355 in the works
Transmission: 4 speed goin to th400
Axle/Gears: stock 9bolt, 3.27
u still got the distributer, if so pm me
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
