comp solid lifter camshaft $125 shipped.
Old Apr 11, 2008 | 06:22 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I'm selling the old combo's camshaft out of my camaro. Was in the camaro for 300 miles and now I'm building up another forced induction combo so this is pulled. Ran great with my vortec heads and 3500 stall. Definitely a raspy cam and would be a good choice for best ET with vortec heads and 9.5:1 compression.
here's the cam card.....
Basic Operating RPM Range: 2,500-6,000
Intake Duration at 050 inch Lift: 242
Exhaust Duration at 050 inch Lift: 246
Duration at 050 inch Lift: 242 int./246 exh.
Advertised Intake Duration: 272
Advertised Exhaust Duration: 276
Advertised Duration: 272 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.520 in.
Valve Lift with Factory Rocker Arm Ratio: 0.510 int./0.520 exh. lift
Lobe Separation (degrees): 106
Intake Valve Lash: 0.018 in.
Exhaust Valve Lash: 0.020 in.
$125 shipped out to your door.
Old Apr 11, 2008 | 07:34 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
Re: comp solid lifter camshaft $125 shipped.
the springs in my vortec heads are good to .550 lift and i have 1.6rockers. could i use this cam with my exisiting valve springs? how often did u have to adjust valve lash with this cam? would i see a noticable gain over my current comp xe274 hydraulic flat cam?
Old Apr 11, 2008 | 08:13 PM
xpndbl3's Avatar
Car: 1984 Z28
yes it is a much larger cam than the XE274 in duration, I adjusted the lash 2 times total, it didnt really change I would imagine once an oil change would be fine, but it only takes 20 minutes so I did it 2 times after break in. It would be a gain over that cam for sure. Most XE274 combos go 12.20s or so, this one is good for a quicker ET.
Old Apr 11, 2008 | 08:32 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
flat tappet or roller?
Old Apr 11, 2008 | 08:37 PM
xpndbl3's Avatar
Car: 1984 Z28
solid flat tappet.
Old Apr 13, 2008 | 09:53 AM
xpndbl3's Avatar
Car: 1984 Z28
guess i'll just toss this on ebay monday or tuesday then.
Old Apr 14, 2008 | 09:35 AM
xpndbl3's Avatar
Car: 1984 Z28
monday bump .....last chance offer
Old Apr 15, 2008 | 07:29 PM
MaNiAk86's Avatar
Car: 1983 trans am
haha ill be happy with 12.20s if i dont have to take my valve covers off every oil change. wow im used to a fukcin 4 banger s10 and my slowass 305 ha
Old Apr 15, 2008 | 08:07 PM
xpndbl3's Avatar
Car: 1984 Z28
whatever works for you I guess. Not like 20 minutes is going to kill someone, but it'll be on ebay tomorrow then.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
