FS:Double hump heads $250
Old 04-20-2008, 07:16 PM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
I got these heads from a buddy of mine. He had $500 worth of machining done to them,screw in studs,upgraded valve springs. I blew my head gaskets and wanted to use these heads but they cant be drilled for accessories. $250 takes the pair. Have them looked at by a machine shop, and put some Rockers on them and you'll be good to go.
Thanks,
Jeremy
Old 04-21-2008, 02:04 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Re: FS:Double hump heads $250
Would these work good for my TBI 305?
Old 04-21-2008, 06:56 PM
jersyboyy's Avatar
Car: 85 Camaro
Honestly I wouldnt know, I do know they were on a high compression 327 and it was a beast.
Old 04-22-2008, 05:49 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Axle/Gears: 3.42 Auburn
Casting number and pics plz.
Old 04-22-2008, 08:32 PM
jersyboyy's Avatar
Car: 85 Camaro
Will get the casting numbers and pics thursday when I pick the heads up from the shop. Their sitting in the passenger seat of my car thats getting worked on.
Old 04-28-2008, 07:23 PM
jersyboyy's Avatar
Car: 85 Camaro
3917291....67-68...302/327/350..Camel hump,no accessory holes,64cc chamber
Looking up these heads iv found people selling them for 300 with
no work done to them, seeing as these have upgraded springs
new valve guides and some porting/maching I was hoping someone
would hop on them for 250. Any one interested?
Heres some pics.
Attached Thumbnails FS:Double hump heads 0-photo_042808_001.jpg   FS:Double hump heads 0-photo_042808_002.jpg   FS:Double hump heads 0-photo_042808_007.jpg
Old 04-28-2008, 07:25 PM
jersyboyy's Avatar
Car: 85 Camaro
some more pics
Attached Thumbnails FS:Double hump heads 0-photo_042808_004.jpg   FS:Double hump heads 0-photo_042808_009.jpg   FS:Double hump heads 0-photo_042808_006.jpg
Old 04-29-2008, 07:48 AM
bob8703's Avatar
call me stupid but by accessories you mean....... does that mean AC.
Old 04-29-2008, 10:36 PM
Dark Angel's Avatar
Kind of, I have a set of these on my '67 Camaro. There are NO holes on the front of the heads for AC, Alternator..... These would normally have had a short water pump and the accessories bolted to the water pump and exhaust manifolds. So if you were looking to use them with the 3rd gen accessories, they won't work without different brackets.
Old 04-29-2008, 10:41 PM
jersyboyy's Avatar
Car: 85 Camaro
Yup thanks dark angel. I couldnt find any brackets to use on mine in time. I needed the car ready to get back and forth to work and decided to use my current heads. If their are any old school kats building a mean street or strip motor and know anything about these heads you know they make great power for cheap.
Old 04-29-2008, 11:06 PM
Dark Angel's Avatar
Your welcome. Try Camaros.net They are all first gen and have a classifieds section. May get more response there.
Old 04-30-2008, 04:23 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Well in your original post you said they had screw in studs. By the pics it looks like press in studs.
Old 04-30-2008, 06:31 PM
jersyboyy's Avatar
Car: 85 Camaro
I was told they were screw in studs i could be wrong. How can i go about checking for that?
Old 05-01-2008, 05:40 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
On a screw in stud at the bottom near the head it will be octagonal, like the head of a bolt so it can be screwed into the head. If it is just celindrical all the way up then it its a press in stud.
Old 05-02-2008, 12:32 PM
Tiresmokin's Avatar
There is a screw in stud that is just a stud. It has no nut on it. The nut is for use with guide plates. You wouldn't be able to use the stud with the nut unless the boss was machined for it.
TreDeClaw
Theoretical and Street Racing
06-22-2021 08:21 PM
92projectcamaro
01-18-2016 08:00 AM
z28guy134
09-01-2015 11:50 PM
TreDeClaw
08-14-2015 06:58 PM
Quick Reply: FS:Double hump heads $250
