350 short block and vortec heads
I've got a 350 short block, 4 bolt main, cast crank and pistons, flat top 4 valve relief hyper pistons. Bored 30 over, tested for cracks, Comp Cams Xe274 camshaft, new timing chain.
Everything is installed professionally and balanced. New Rings, new bearings all around. 2pc rear main seal.
$650.
I've also got a pair of 062 vortec heads. Went to the shop, cleaned up, checked for anything that would prevent me from using them. New springs, to match the Xe274(Comp cams suggstion), newer roller tip rockers(Got them from someone, said they only had a few hundred miles on the engine, he sold bottom end.)
$350
Located in Staten Island, Ny, 10307.
Steve
Asuryan4520@aol.com
$650.
$350
Steve
Asuryan4520@aol.com
Re: 350 short block and vortec heads
Ok, good luck finding a set. I believe they are 62, or 60? I dont remember what the stock vortec heads came in.
Once again, TTT.
Heads $300
Short block $600
Once again, TTT.
Heads $300
Short block $600
Want a title? Post!
Car: 1987 fFirebird
Engine: 350/304rwhp
hey, I know that this post is old but do you still have that 350 for sale? let me know or e-mail me at Mikecarp@sbcglobal.net i need to swap out my 305 for a 350 and this looks like a good way to go so let me know.
Thanx-Chris
Thanx-Chris
