Rear, Sub frame connectors and more forsale!!!
Car: 1987 Iroc-Z
Engine: 5.7L SB
Transmission: TKO 500
Axle/Gears: 10 bolt 373's and a Detroit Locker
I have a stock 9 bolt with 323's. It works fine and has 60,000 on it posi is not working but every things else is great. It has new rotors and brakes. $150
Pick up please because it weighs ALOT...
stock intake off of an 87 Iroc mint condition $75
Stock LCA's from an 87 Iroc with 60,000 on them $50
Competition Engineering Sub frame Connectors (weld in) Brand new! $80
10 bolt 7.625', 327's ring and pinion with posi if you want it not sure if it works or not has bearing on the ring and pinion and carrier I believe 80$
All of these are plus shipping unless you want to pick them up let me know
Thanks,
~Chris
Thanks,
~Chris
Car: 1987 Iroc-Z
Engine: 5.7L SB
Re: Rear, Sub frame connectors and more forsale!!!
C3046 I believe i have had some one else ask so ill post the pics tomorrow or Friday but im pretty sure thats the number
~Chris
~Chris
Car: 86 Iroc-Z
Engine: 310ci soon to be 355ci
Transmission: built 700r4
Axle/Gears: I think 3.08s
Sfcs do you have to modify your exhaust for these or are they bent for the passenger side, pics to nitrochargedv8@yahoo.com thanks
Car: 1987 Iroc-Z
Engine: 5.7L SB
Theses will work with the stock exhaust but im not sure about anything much bigger than 2.5 inch piping...
~Chris
~Chris
Car: 1987 Iroc-Z
Engine: 5.7L SB
Hey guys the camera is on the fritz so i won't be able to upload the photo's. The part number gives a picture if you google it
~Chris
~Chris
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
When you say intake off an 87 Iroc, are you talking about the TPI setup or just the base intake?
May be interested......
Car: 1987 Iroc-Z
Engine: 5.7L SB
This is from the tb (to the filters) all piping and snorkle...
~Chris
~Chris
Car: 1987 Iroc-Z
Engine: 5.7L SB
SFC's sold...
Thanks ssJlink4!!!
Thanks ssJlink4!!!
Car: 1986 Z28 Camaro, 2002 Audi A4 (DD)
Engine: 350 .30 over w/bang for buck combo
Axle/Gears: stock for now
the 9 bolt is a posi? or no? is the 10 bolt a posi?
Car: 1987 Iroc-Z
Engine: 5.7L SB
The 9 bolt is a posi complete rear with brakes and all. The 10 bolt it just the gears and carrier with the stock bearings.
Made to go into a 10 bolt not the housing or axles.
~Chris
The 10bolt carrier is a posi which i was told works but im not sure which is why it is not luisted as high as a working one... 85% sure that it works. The carrier works fine to drive in but maybe be a one legger if you know what i mean.
~Chris
~Chris
~Chris
Last edited by SpiderViper; Sep 30, 2008 at 09:51 AM. Reason: Automerged Doublepost
1992 Trans Am
May 10, 2023 07:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
