LOOK!!!! 454 BBC "All forged internals" Good Price!!
Car: 1984 Z28
Engine: 355ci
Transmission: WC T-5 (untill it breaks)
Axle/Gears: 3.73 Posi
This is out of my brothers pulling truck, we swaped it out for a diesel. there is nothing wrong with this it pulls very strong. It has as follows,
-forged steel crank
-forged I-Beam connecting rods
-forged aluminum pistons
-2bolt main block w/arp studs
-.030 overbore
-new cam bearings
-new freeze plugs
-new double roller timing set
-new oil pump
-comp cam dur 268int 268ex/lift.485int 485ex
-open chamber oval port, new seals, new guides, new seats, machined out to 2.19int valve/1.88ex valve
-high flow water pump
-professional products aluminum intake
-speed pro one pice push rods
-magnum rollar rockers
any additional questions feel free to ask
thanks
-forged steel crank
-.030 overbore
-new cam bearings
-new freeze plugs
-new oil pump
thanks
Car: 1984 Z28
Engine: 355ci
Re: LOOK!!!! 454 BBC "All forged internals" Good Price!!
pistons do have a small dome, should be about 10to1 compression
Car: 1984 Z28
Engine: 355ci
shurly someone out there could use a big nasty RAT motor to drop in their third gen!
Car: 1984 Z28
Engine: 355ci
2300.00 we could except a partial trade possibly fepending what you have to trade!
thanks
thanks
Car: 1984 Z28
Engine: 355ci
I cant belive no one needs a rat motor, need to sale no reasonable offer turned down!!!!!!!!
Car: '84 Z28
ya they wouldn't mind if they had money to blow, but for 2300.00 you could put a 350 at over 400HP without the hassel of swapping motors. what year is the motor?
Car: 1984 Z28
Engine: 355ci
I second the motion!!!!!!!!!!!!!!!!!!!!
Car: '84 Z28
I'm not hating on BBC's, you can definatly put out a **** ton more power with the 454 than you can any SBC. if you had the money.
these are on a 350 chevy shortblock out of hot rod magazine. i'll give you stock vortec heads and afr 195 heads. these are with different camshafts that would put you at these numbers. these have been tested.
1495.00 for the 195 AFR heads
450+ for the camshaft
These also had headers on them and im sure a performer intake manifold. but in the end you get around 2300-2400$$$
xe268h-10 1500-5500 rpm: 409 tq @4000, 372 hp @5400. afr heads: 420 tq @ 4200, 418 hp @ 5800 rpm.
magnum 280h-10 2200-6200 rpm:403 tq @ 4300, 378 hp @ 5700. afr heads, 422 tq @ 4300, 426 hp @ 6100.
xe274h-10 1800-6000 rpm: 414 tq @4100, 385 hp @ 5600. afr heads: ... didn't give exact #'s. all they said was "afr's head are worth about 47 hp and 12 torque" give or take some
magnum 292h-10: 407 tq@ 4300 rpm, 400 hp @ 6000. afr heads: 415 tq @ 4700, 450@ 6400
283thr-107:418 tq @ 4200, 396 hp @5900. afr heads: 436 tq @ 4300, 453 hp @ 6200
Car: 1989 IROC, original 20,000 mile
with the price of fuel now a days, I am building small blocks 8-1. but a 454 will get moving faster!! The new mark, with todays technology for gen 1 small blocks is 500 fwhp. Last edited by lltrevino; Sep 30, 2008 at 02:12 PM.
Car: 1984 Z28
Engine: 355ci
Car: '84 Z28
Ya, BBC's have a ton of power, i own a 91 GMC 2500 with a 454, i've done minimal work on it and i love the TQ! lol. but you work a SBC right, it will scream like mad
Car: 86 camaro
Engine: 406 sb
Axle/Gears: working on that
sorry i missed the part where you added up the cost of a short block, i pretty sure thats not a stock short block, how about adding $500 for pistons, $400 for block work, good bolts hell maybe even rods and crank
Car: '84 Z28
it was stock, you don't have to redo them, if you do its just to make sure they are touch enough to handle the power. wtf? you don't need pistons unless you bore/stroke it or want a different compression ratio.
Last edited by 10secondhopeful; Sep 30, 2008 at 02:21 PM. Reason: Automerged Doublepost
This particlular article was done on a junk yard engine, not even freshened up, just replacing top end, FYI hence the name "junk yard gen 1 jewel" than also the did the same to a truck junk yard 5.3 and got 650hp
Car: 86 camaro
Engine: 406 sb
stock internals, no bore, no stroke. with that much power i'm sure they added new fuel rails and oil pump etc etc. its advised to redo your block, but when most people think about that, they figure if they are doing that they might as well bore 4.030" over and give it a 3.750" stroke for a 383.
sorry i never seen a stock short block (8.5cr) makle 400hp without power adder Member
Car: '84 Z28
he's talking about the 5.3L, we are talking about putting a 350 at 400 HP, but either way, ITS STILL A SBC
Last edited by 10secondhopeful; Sep 30, 2008 at 02:44 PM. Reason: Automerged Doublepost
Car: 1984 Z28
Engine: 355ci
those articles in those mags can be very misleading, You have to remember they get kick backs of the advertising they do, and you really think any of the manufactures that are giving them money, that the mag is going to give them a bad review. Im not saying it cant be done, but what I am saying is I just dont see it happening for 2300.00. also in some of the car mags on the last page or so on the parts brake down, it will tell everything that went into the engine and 9out of 10 times its not what they started the article off with! just my two cents. But any-way this thread was trying to get this engine sold not debate witch is a better build!
thanks
thanks
Car: '84 Z28
thanks
thanks
Car: 1984 Z28
Engine: 355ci
well I guess ill leave it for sale on here till friday, then its off to e-bay
thanks
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Car: 1984 Z28
Engine: 355ci
Car: '89 IROC-Z
Engine: 355
just a cam, intake and carb. I wouldn't call that a heck of a lot more. ask me i've done it
Car: 1984 Z28
Engine: 355ci
Then your one heck of an engine builder beacuse I have never seen it done, and spend most of my spare time at my brothers dyno shop and havent seen it done there eather, post a dyno sheet I would like to see it!
Car: '84 Z28
sgreen, just look around! these guys are pushing 12 second quarter miles with heads, cam, headers, intake, and other mild bolt ons. if you don't believe me just look around!
Car: 1984 Z28
Engine: 355ci
do any of them have any posted time slips with what kind of build theire running, im not saying i do or dont belive any one, but if your going to make claims its a good idea to have prof to back them up, and again how did we get off the subject at had once again!
Car: '89 IROC-Z
Engine: 355
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
