[PA] 9 Bolt rear (3.27s Disk) 250$
Old Mar 9, 2009 | 02:50 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Just bought it. my dad said its too hard of a job to put in and wont let me do it.
The rotors are good on it. I looked up the s/n its an 89
Old Mar 9, 2009 | 10:09 PM
chopper's Avatar
Car: 1992 Z28
Engine: 5.7 L98 TPI 10 over stock
Axle/Gears: 10 bolt 3.73 Richmond
Re: 9 Bolt rear (3.27s Disk) 250$
If it came out of a 3rd Gen F-body and you want to put it into a 3rd Gen F-Body it's just the same as replacing: shocks, springs, LCA's, and brake lines. If you can do that you can swap a rear end. Not the hardest thing imho.
Old Mar 9, 2009 | 10:14 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Are the brake lines different from my drum 88 10bolt? This came out of a 89 GTA
Old Mar 9, 2009 | 10:16 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
If it is out of an 89, it would have PBR brakes which are way better then your drums. Tell your father it would be safer and you want to put it in!
Old Mar 9, 2009 | 11:25 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I was able to swap out my drum 10 bolt for my disk 9 bolt in a single day. And that included giving the paint on the 9 bolt a chance to dry. I put a coat of paint on before I went to school, then came home, swapped rears, bled the brakes and went to school the next day with what felt like a new car. As long as you have access to a torque wrench, a breaker bar, metric socket set, a way to bleed the brakes, and you understand the "lefty loosy, righty tighty" concept you'll be fine. Oh, jack stands are a must as well and some PB Blaster or other penetrating stuff may be needed.
I'm still in high school too, so I have some experience working on cars but not all that much.
Old Mar 9, 2009 | 11:51 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Upgrading to rear disks will help you slow down smoother and faster, plus 4wheel disk just looks sweet.
Old Mar 10, 2009 | 10:29 AM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Are the brake lines the same?
Old Mar 10, 2009 | 03:12 PM
Car: 1987 IROC-Z
Transmission: TH350
Brake lines are the same.
You should also change the speedo gears in your transmission so your speedo will be accurate with the new gear ratio. It isn't necessry, it is just nice knowing exactly how fast your going.
Old Mar 10, 2009 | 09:08 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
I convinced him to let me do it under his supervision, he thought more things were different then my 10 bolt. I have access to just about every tool I'll ever need (hes been mechanic since he was young and have quite a collection of tools and knowledge)
The rear is no longer for sale.
Old Mar 10, 2009 | 09:44 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
If he is a mechanic, Why doesn't he give you a hand?
Old Mar 10, 2009 | 09:46 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I think the e-brake cable is different. I am not sure though.
Old Mar 10, 2009 | 11:38 PM
Car: 1987 IROC-Z
Transmission: TH350
Yup, the ebrake cables are different. I still have to get some for my rear unless I find a 98-02 rear end first. lol
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
1nastygta
Aug 8, 2015 07:38 PM
