[Sold] TPI Throttle Body's
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
TPI Throttle Body's
i have 2 TPI TB's for sale
***SOLD***the first has a polished top plate and screws, includes the IAC and TPS sensors, bolts and gasket, $70 shipped
***SOLD***the 2nd has a black and white top plate that i painted, looks okay, also comes with IAC and TPS sensors and i may have another gasket to throw in, one of the coolant passages was cut off(coolant bypass mod) $50 shipped
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: TPI Throttle Body's
I know off topic but where would i be able to find the iac hosing ( the thing with the coolant hoses) or are you willing to sell it ? alone?
Car: 88 Trans Am 5.0L TPI
Engine: 305 TPI (LB9)
Transmission: 5 speed manual
If you have it monday (or today it is 1 am here) I will take it. I have a throttle body with a crack where the hose goes and it leaks. I have to wait till monday to make sure my friend didn't order one already.
a crack where? if its a crack in the coolant passage, mine has the spouts for the coolant cut off. if urs is cracked somehwere else then its fine
bump... still got one here, complete with TPS and IAC sensors, black and white painted top plate, and coolant bypass $50 obo
mdtoren
Aug 16, 2015 05:45 PM
