[OH] engine swap left overs
Car: 85 Trans Am
Engine: 383 HSR
I got a few things to sell...
305 short block with HO heads and a .488 lift comp cam. the heads were rebuilt 1000 miles ago and block has about 60000 original miles-$250
2 153 tooth sfi approved flexplates one for internal balance and one for external balance- $30 each
2 sets of barely used 19 lb injectors-$60
stock ws6 pack. springs- make offer
that's it for now may add more in a few days
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
Re: engine swap left overs
what was included in the heads rebuild and what is the casting #?
Car: 85 Trans Am
Engine: 383 HSR
ill get the casting #s when i go home this weekend. the heads have all new valves, seals and springs to handle the cam i got.
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
any idea on valve size, and brand and what amount of lift the springs can handle. Were the heads milled if so how much. were the guides milled down to make sure you can run a decent sized cam, side bolt or centerbolt?
Car: 85 Trans Am
Engine: 383 HSR
the casting number for the heads-14014416 then theres a number under it-F216 the engine and heads are from a 1986 monte carlo ss. the valves are stock size.
Car: 85 Trans Am
Engine: 383 HSR
the engine was a carberated 305. 4 barrel 305 HO. It comes with block and heads together just needs intake and carb. I took my roller rockers off of it also so you will need some rockers. Just make an offer
theshackle
Mar 5, 2017 06:37 PM
