[MI] carbs, engines, headers, and more for sale.
Old May 23, 2009 | 10:27 AM
hectre13's Avatar
Car: 1984 15th Anv. T/A
Engine: HO 5.0
Transmission: TH700r4
Axle/Gears: not sure yet!
Hey all,
I got a bunch of stuff for sale here. the main thing I'm trying to sell is my carb.
Holley 600, has less than 100 miles on it since rebuild, works good, looks brand new, it is currently still on the car, I can let you hear it run, it just isn't right for my setup. looking to get $200 for it.
1 - ($75) holley carb off a mustang, in real good condition (manual trans)
1 - ($20) carter mechanical fuel pump, stock style (used)
1 - ($125) hedman headers, ypipe with flowmaster
1 - ($50) great condition radiator (manual transmission only)
2 - (make offer) 350 short blocks (need rebuilt)
2 - (make offer) SBC starters (one is for a truck, other is for a camaro)
1 - (make offer) V8 700r4 transmission (needs new front pump)
1 - (make offer) V6 200r4 transmission (should be fine)
1 - ($150) 4" harwood pin on fiberglass hood (very little crack up front)
1 - ($50) stock steel hood
1 - ($50) set of blue stock 83 seats (good condition)
1 - (make offer) V6 driveshaft
1 - (make offer) V6 transmission crossmember
1 - (make offer) V6 sway bar
1 - (make offer) set of RS side GFX (maroon, only the sides)
1 - ($150) set of IROC rims, need cleaning up (single fat stripe)
1 - ($10) summit chrome drop base air cleaner, with filter
1 - ($20) summit air filter (14inch round, 2inch high, never used)
1 - ($10) comp cams cam button CCA-211 (never used)
1 - ($15) proform black crinkle steel timing chain cover (never used)
lemme know, and I can get pics of any of these.
Old May 23, 2009 | 12:55 PM
davidz28's Avatar
Re: carbs, engines, headers, and more for sale.
is that header and y pipe and flowmaster still availible. if so i might can pic it up in a week or two. i live in n.c. dont mind driving. are they long tubes or shorties and is that your lowest price. please pm me or email me at davidz28man@yahoo.com thanks
Old May 23, 2009 | 02:38 PM
hectre13's Avatar
Engine: HO 5.0
yes they are still available, they are shorties, they will need some cleaning up, they were black new, i cleaned them up a little and painted them silver, but they will need cleaned up again.
Attached Thumbnails carbs, engines, headers, and more for sale.-100_2029.jpg   carbs, engines, headers, and more for sale.-100_2032.jpg   carbs, engines, headers, and more for sale.-100_2036.jpg
Old May 23, 2009 | 08:22 PM
youngguns251's Avatar
how much shipped ( for the cowl hood ) to 36695? also, can I get a pic f the hood?
Old May 24, 2009 | 03:49 PM
hectre13's Avatar
Engine: HO 5.0
I can get you pics, but I wont be able to ship it, big items are pick up only, sorry.
Old May 25, 2009 | 06:40 PM
hectre13's Avatar
Engine: HO 5.0
TTT everything is still for sale.
Old May 25, 2009 | 08:55 PM
91camaro372's Avatar
Car: 91 Camaro RS
Engine: 3.1L v6
Axle/Gears: 2.73(for now) posi disc from 95 Z28
Hey can I get picks of the Iroc rims?
Tim
Old May 25, 2009 | 09:35 PM
hectre13's Avatar
Engine: HO 5.0
yea, ill snap a pic of them tomorrow.
Old May 25, 2009 | 11:16 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
more info on short blocks and that 700r4
Old May 25, 2009 | 11:18 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
are they d port headers?
Old May 26, 2009 | 06:15 AM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Will the headers fit a lt1 motor?
thanks
kevin
Old May 26, 2009 | 11:06 AM
hectre13's Avatar
Engine: HO 5.0
I have 2 5.7L short blocks, one of them came from a late 80's silverado, its 2 bolt mains, non roller cam. it had L05 heads on it. the reason I originally bought this block was to just drop it in and go, but the cylindars werent giving me any pressure, this engine is just worn out, needs a good rebuilding.
the second engine came out of an 89 camaro, it was an L98 block with the roller cam, it even still has all that stuff with it. I drove this engine for awhile, but threw a bearing, doesnt look like any block damage.
the 700r4 I just went and looked at, it needs a good overhaulin also, I don't even know if its worth anything anymore, I was told the front pump was bad on it, but instead of putting money into fixing it, i just went and bought a different one, the one i bought had an electric speedo unit, so i swapped for the one on the old trans, so this transmission has an electronic sender. also I needed a new gear selector shaft, so i went to steal it from this trans, but couldnt get it out all the way, so its just sticking half way out, lol.. i guess for a core this trans would be good, heck if you buy one of the engines, you can have the trans free. comes with a torque converter, from what im told the converter is a b&m
The part number for the headers and ypipe are.
Hedman 68470
Hedman 17470
if you click the links, it will give you any and all information about them, I'm not really sure what d port headers are, but i believe they are for stock style heads, if that answers your question.
thanks
kevin
I don't believe so, you'll have to do some research on that one, sorry.
Old May 27, 2009 | 12:58 PM
BlackFormula's Avatar
Car: 92 Camaro RS
Engine: 350 ci Carb
Transmission: 5speed
Headers available?? if so, how much shipped to 28079??
Old May 28, 2009 | 11:01 AM
Irocz207's Avatar
Car: 90 Camaro RS
Engine: 3.1
pm me on the price of the 350 that came out of the camaro
Old May 30, 2009 | 10:37 PM
hectre13's Avatar
Engine: HO 5.0
Tim
sorry for the wait, this was just a quick snap shot of one of the rims, they are all pretty much in the same shape as this one.
I'll get a price asap, I'm out of town until tuesday.
I was looking to get like 75 bucks for the engine, pickup only
Attached Thumbnails carbs, engines, headers, and more for sale.-0529091225.jpg
Old May 31, 2009 | 12:05 PM
petko0's Avatar
Engine: built 350 TPI
im interested in the summit air filter and the v8 700-4r. petko0@yahoo.com
Old Jun 3, 2009 | 03:37 PM
Car: 92 Camaro RS
Engine: 350 ci Carb
did u get a price with shipping to 28079 yet? intertesed, but need numbers asap to know how much im lookin at. thanks!
Old Jun 5, 2009 | 11:49 PM
hectre13's Avatar
Engine: HO 5.0
make an offer.
sorry, I was on a trip to new york, and things have been hectic lately, let me see what i can find out on shipping, thanks!
Old Jun 6, 2009 | 04:12 PM
tonyc662's Avatar
Where in mich. are you located? I'm interested in the motors.
Old Jun 6, 2009 | 04:22 PM
hectre13's Avatar
Engine: HO 5.0
monroe, southeast michigan.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
