[FL] Heads, Cam, Blocks, Rods For Sale
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
Borg-Warner 9 bolt differential 3.27 gear complete with calipers, sway bar, and e-brake cables.....SOLD
L-98 Cast Iron Heads Assembled with valves and Comp Cam Springs $200.00
Dart Iron Eagle Heads assembled with 2.02 intake and 1.60 exhaust, dual springs and 72 cc chambers.....SOLD
Cast Iron Small Block intake manifold for Quadrajet Carb $30.00
Unassembled 305 Heads with valves and springs $75.00
400 small block – bare block with 2-bolt main caps $100.00
5.7L short block – needs rebuild $250.00
Comp Cams Hydraulic Roller Retro Fit Cam # 12-423-8 XR 276 HR. 0.502"/0.510" lift, 276 / 286 duration, 110 Lobe separation with Crane Cam retrofit Hydraulic Roller Lifters . $300 for the package
Set of 8 Small Block 400 Connecting Rods $50.00 for the set
Bare LT1 intake manifold $50
LT1 pistons and rods, stock bore, nice shape Set of 8 $50
LT1 Throttle body $50
Pay pal or cash. Prefer local pick-up if possible to avoid hassles of shipping. Prices do not include shipping. All parts are located in Ft Lauderdale, Florida zip - 33309.
Re: Heads and 9 Bolt Differential For Sale
I will take a couple of pics and post them. They should be up either this evening or by tomorrow morning at the latest.
Just as a sidebar, the diff has rotors, PBR calipers, sway bar, e-brake cables, and brake lines.
Thanks for your interest.
Here are some pics of the diff.
Pics of Dart Heads
Car: 1985 Pontiac Trans Am
Engine: 6.6 Liter 406 c.i.
Transmission: T-56 6 Speed/ McLeod Street Twin
Axle/Gears: 3.42 9 Bolt Posi w/ girdle
Can I have more info on the heads? Part numbers, runner volume, and valve sizes? I have a healthy 406 with S/R Torquers on there now... are these heads better?
Monday morning bump...
Re: Heads, Cam, Blocks and 9 Bolt Differential For Sale
Just added: Set of 8 Small Block 400 Connecting Rods $50.00 for the set
Re: Heads, Cam, Blocks, Rods and 9 Bolt Differential For Sale
400 block has stock bore with light ridge at top of cylinders. It will probably need a slight overbore.
PM sent
PM sent
Car: 1986 Iroc z
Engine: 350 tpi
TTT
TTT
Re: Heads, Cam, Blocks, Rods For Sale
Sold the differential last night.
They are standard factory cast iron L-98 heads. 64 cc chambers with 1.94/1.50 valves. They have comp cam 981 springs installed and new seals. The heads also have the "canted" middle intake bolts.
A few additional items added to list...
