Garage Clean Out
Old Sep 17, 2009 | 07:10 PM
chevy35086's Avatar
Car: Camaro z28 1986
Axle/Gears: 3.42's
Garage Clean Out
This is just the start of it sadly.....
ALL PARTS ARE OBO AND HAVE COME FROM A 01 SS CAMARO WITH 72K ON IT.
Stock Headlights $80
Passenger Window $40
Drivers Window $40
Rear Bumper (Black, Good Paint) $60
A4 Transmission Cross Member $25
Dash Brace $10
A4 Transmission Hard Lines $20
Passenger Side Wiper Cowl $15
Drivers Side Rear Wheel Well Plastic Piece $5
Cruise Control Setup $50
Heater Hard Lines/Hoses $25
Drivers Side Inner Hatch Wheel well Plastic Piece $5
Underbody Tunnel Brace $15
Rear Bumper Plastic Brace $25
Panhard Bard with Upper Brace $25
Front Strut $10
Heater/AC Box $35
Fuel Hard Lines/Brake Hard Lines Full Body Length $50
Heat Shields $20
Rear Spring Isolators $15
Full Dash (Cracked) $20
Passenger Knuckle with Hub $35
Window Motors/Tracks $35
Window Weather Striping Tracks $20
T-top Weather Striping Drivers and Passenger Side $40
Serpentine Belt $5
Smog Pump Lines $5
E-Brake Main Cable $8
Door Plastic Noise/Weather Shields Passenger and Drivers Side $10
Rear Hatch Struts $15
AC Dryer $15
Cowl Weather Striping $5
Passenger Window Corner Trim $10
Drivers Window Corner Trim $10
Gas Tank Filler Surround $5
Door Lock Push Rods $10
ABS Block Bracket $10
Rear Body Vent $5
Upper Control Arm Brackets $20
Front Sway Bar Brackets $15
Hatch Pop $8
Master Cylinder Lines $5
Steering Column Brace $5
AC Compressor Bracket $25
Upper Radiator Hose with Power Steering Cooler $20
AC Dryer Bracket $5
ABS Block/Pump $30
Master Cylinder (Two Available) $20 Each
Wiper Motor $15
Misc Hardware (Ask)
Rack and Pinion $80
Torque Arm $30
Full Body Harness $100
Drivers Side Door (No internals Includes Lock, Handle, Hinges) (Black, Good Paint) $40
Passenger Side Door (Complete door) (Black, Good Paint) $65
K-Member with A-Arms $65
Fuel Tank (Pump, Sending Unit, Canister, Plastic Lines) $100
Drivers Side Kick Panel $25
Passenger Side Kick Panel $25
Drivers Side A-Pillar $20
Passenger Side A-Pillar $20
Drivers Side Sail Panel $40
Passenger Side Sail Panel $40
Hatch Plastic Panel $20
Center Console with Lid $100
Passenger Side Rear Panel $15
Drivers Side Rear Panel $20
Two Sony Speakers Round (XS-R1342) $20
Drivers Side Dash Vent $8
Passenger Side Dash Vent $5
Under Steering Column Plastic Panel Support $5
Glove Box $20
HVAC Controls $30
Hatch Release Button $5
Passenger Side T-top Pin Cover $4
Drivers Side T-top Pin Cover $4
Rear Speaker Grill $10
Rear View Mirror $15
Gauge Cluster Surround $15
Jack Cover with Screw $5
Under Dash Plastic Panel (Gas Pedal Area) $10
Sail Panel Foam Support Blocks (two) $5
Rear Shock Upper Foam Covers (two) $5
Standard Antenna Base with Rod $10
Under Carpet Insulation $5
Sun visors (Need Recovering, Good Core) $15
Passenger Under Dash Panel $10
Under Column Hard Cover $10
2001 SS Owner’s Manual Set $15
Hatch Storage Area Door $25
Vent System Piece $4
E-brake with Handle $20
A4 Shifter $20
Delco Amp $15
TPS Controller $25
Tail Light Harness $15
Two PCM Gaskets $5
Two Pioneer Round Speakers (TS-G1642R) $25
Two Sony Speakers (XS-R1642) $20
Center Console Cup Holder Linder $8
Air Box Rubber Seal Flap $4
Tire Hold Down $2
Hood Latch $5
Hood Latch Support $5
Head light top support $2
Two Red Toggle Switches $6
MAP Sensor $12
Brake Booster Hose with Check Valve $6
Fender Support (Upper) $2
AC Dryer Line $5
A4 Shifter Bezel (Has Crack) $15
Passenger T-top $100
98 Z28 hatch has some damage but good tinted glass $20
Third Gen Parts/SBC
82-92 Gas tank brand new $150
Gen I sbc crank 350 $50
82-89 Camaro Spoiler 3 piece $45
82-92 single cooling fan $20
82-89 Camaro gauge cluster 85mph speedometer $30
Hei dizzy (no cap or rotor) $20
2 power steering pulley's 2 grove v-belt press on $5 each
86 hatch glass and deck lid $40
86 hatch glass $30
Old Sep 17, 2009 | 08:44 PM
F-Body_Fetish's Avatar
Car: 1984 Camaro Z/28
Engine: 350 SBC
Re: Garage Clean Out
Unreal! this has to be the most thorough part-out post I have ever seen. props, unfortunately I don't need anything. but hey, tiny bump for you.
Old Sep 22, 2009 | 08:50 PM
chevy35086's Avatar
Axle/Gears: 3.42's
BUMP
Old Sep 27, 2009 | 12:22 PM
chevy35086's Avatar
Axle/Gears: 3.42's
BUMP, lots of stuff to get rid of, make some offers.
Old Sep 27, 2009 | 12:42 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Would you seperate the thirdgen spoiler
Old Sep 27, 2009 | 01:09 PM
DJ Delsym's Avatar
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
The third gen tanks come with the filler neck? Also, where is jersey are you?
Old Sep 27, 2009 | 01:48 PM
j.prince428's Avatar
Car: 1983 Z28
Engine: 5.7
Axle/Gears: UNKNOWN
I'll take the 2.73 rear for the third gen.
Old Oct 2, 2009 | 08:36 PM
chevy35086's Avatar
Axle/Gears: 3.42's
BUMP
Old Oct 4, 2009 | 12:12 PM
pr0zac's Avatar
Car: 1991 z28
Engine: forged 385 with afr's
Transmission: built 700r4
Axle/Gears: 9" and 4.56
pics of crank to joshua.huber@hotmail.com..
Old Nov 4, 2009 | 04:10 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
1. Doeskin Tan color interior plastics for the trunk, T-Top Headliner, T-Top Sunvisors, carpet, doors, seat belts.
2. center console light
3. 82-84 Firebird Trans Am Fenders with air collector vent.
4. 82-84 hook style t-tops
5. fuel pump sending unit for crossfire fuel injection 305CI V8 S VIN code
6. 15 inch Bowling Ball Hub caps
7. 1982-1984 305ci V8 mechanical fan shroud
8. 1982-1984 gauge cluster
9. Crossfire Incjection parts
10. cruise control unit
Old Nov 8, 2009 | 07:07 PM
chevy35086's Avatar
Axle/Gears: 3.42's
BUMP
Old Nov 15, 2009 | 12:38 PM
chevy35086's Avatar
Axle/Gears: 3.42's
BUMP
Old Nov 15, 2009 | 12:58 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
maybe have the LS1 driveshaft?
Old Nov 24, 2009 | 11:27 PM
S_Johnson's Avatar
Car: 87 T/A
Engine: 400SBC Carb'd
Transmission: T56, Kevlar clutch
Axle/Gears: 3.73 Yukon Duragrip posi
I'm confused, do you have relocation brackets for the "lower control arms?" It seemed like it in your post. Thanks.
Old Nov 25, 2009 | 10:19 AM
0pyders's Avatar
Car: 86 Firebird LG4
will the wiper motor fit a 1986 firebird with delay?
Old Jan 3, 2010 | 12:12 PM
chevy35086's Avatar
Axle/Gears: 3.42's
BUMP
Old Jan 3, 2010 | 03:49 PM
ownor's Avatar
Engine: LS1 / L03
bump. got US shipping address.
Old Mar 2, 2010 | 06:37 PM
blairva122's Avatar
is that a complete center console? where are you located in jersey? i am looking for coplete center console for a standard trans. located in central ny so picking up wont be a problem. could you post a pic please?
Old Mar 2, 2010 | 10:12 PM
HOTROD82CAMARO's Avatar
Want a title? Post!
What condition is the drivers door in?
Old Mar 3, 2010 | 09:40 AM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Axle/Gears: 3.42 posi
do you still have the 350 crank? if so can i get pics to bluecamaross20@yahoo.com? and what would shipping be to Osceola indiana? thanks Ty.
Old Mar 3, 2010 | 12:47 PM
Drew's Avatar
Hot Tip #95: When someone hasn't posted to a classifieds thread in over a month, don't bump it back to the top with a question. Use the PM system or try sending them an email. Otherwise, they probably won't see it.
Old Mar 10, 2010 | 11:22 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Hood hinges?
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
gta892000
Sep 16, 2015 12:37 AM
Randomtask2
Sep 10, 2015 08:37 AM
84 TA NV
Sep 6, 2015 08:02 PM
