[IL] WS6 Sway bars with poly everything
Old Oct 22, 2009 | 03:52 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
Front and rear sway bars from my 91 T/A. Front comes with TDS greasable kit and energy end links (not pictured). Rear is all energy bushings and end links. They have a five year old rustoleum paint job on em, absolutely zero rust ever. Bushings have ~4300 miles on em $100 plus shipping or meeting is possible
Old Oct 22, 2009 | 07:59 PM
phoenix_rising's Avatar
Re: WS6 Sway bars with poly everything
How would these compare to the stock swaybars on my '86 305 TA?
Old Oct 22, 2009 | 09:56 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
is it a WS6 car? Im not sure what would have come on that stock. These will reduce body roll while cornering compared to lesser bars
Old Oct 23, 2009 | 04:27 AM
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
what size are these and are they hollow or solid.thanks
Old Oct 23, 2009 | 12:19 PM
MADMAXGTA's Avatar
Car: 89 TTA
got a part number?
Old Oct 23, 2009 | 05:17 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Take a metric wrench and slip the end over the swaybar away from any bends preferably right in the middle of the bar.
If it is a true WS6/1LE set, the front will be a hollow 36mm bar (there should be a little hole on each end to prove it's hollow), and the rear will be a solid 24mm bar. I would think that as long as he greased his bushings well, they should still have plenty of life left.
Originally Posted by XxCoLTxX
got a part number?
All of the bars I have and had (which is a lot) never had part numbers on them. You just have to go by size.
Old Jun 15, 2011 | 06:42 AM
Hyper Tailz's Avatar
Car: 92 Camaro RS
Engine: 3.1
Transmission: Manual
i know its a old post but do u still have them??
Old Nov 1, 2011 | 12:07 AM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
i pm you
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
