[CT] 383 stroker motor, all forged, all roller, TPIS miniram
Old May 18, 2010 | 07:56 PM
chevy014life's Avatar
For sale is a 383 stroker (not assembled) the block is a 4 bolt two piece rear main seal, bored 30 over:
Crank: Eagle Forged
Rods: Eagle forged H beam, full float W/ bushings and ARP studs
pistons: Speed pro Forged flat tops
Rings: Mahle rings
Bearings: Clevite 77 (ALL)
ALL ARP STUDS.. heads/ Mains
Heads: Dart pro 1 200 angle plug/ fully assembled, w/studs and guideplates
Fluidamper
TPIS ZZX roller cam
Comp cams pushrods
Comp cams cromoly roller rockers with 7/16 studs
Roller lifters RETROFIT
Comp cams 3 piece timing cover
Cloyes Billet double roller timing set
Moroso oil pan for 86 Camaro 7 qt
Milodon oil pump (big block high volume)
ARP hardened oil pump shaft
oil pump pickup
Oil pump stud ARP
GM performance aluminum valve covers
TPIS mini ram intake
TPIS 58 mm throttle body
TPIS injectors
TPIS fuel rail kit for mini ram
TPIS custom burn chip.. for a 1986 camaro with a t56 and 410s and this motor combo
Centerforce flywheel for 2 piece rear main and t56
Motor is not assembled. The block has been machiened, cam bearings installed ready to assemble... ALL PARTS LISTED ARE BRAND NEW IN THE BOXES.
lookin for $10,000 I will assemble the motor if you want
E-mail me with questions: Arctic_cat_c7@hotmail.com
Old May 18, 2010 | 08:40 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: 383 stroker motor, all forged, all roller, TPIS miniram
I am not trying to be "that guy" but several engine have been for sale on the boards for several years, for instance a fully forged 406 has been on the boards for over a year at $2800 with no luck. I am just saying you might want to try your luck elsewhere also. Your combo looks very similar to mine, except mine a 1 piece rear main seal, and I have a 700 r4. Makes really good power with the mini ram and zz409 cam
Old May 18, 2010 | 09:42 PM
hutchenc's Avatar
Since it's unassembled, you might consider selling the pieces separately.
How much for the mini-ram?
Old May 18, 2010 | 10:39 PM
tekkitan's Avatar
Car: 87 IROC-Z
Agreed, especially since you can find a fully forged 454 small block fully dressed for around his asking price.
Old May 21, 2010 | 10:08 AM
v8 drift's Avatar
Car: 84 Z28
Engine: 355
Transmission: t56
Axle/Gears: 4 11
would you sell just the flywheel
Old May 31, 2010 | 10:19 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
how much for the Dart pro 1 200s
Old Jun 13, 2010 | 06:39 PM
MitchellTN's Avatar
Want a title? Post!
Car: 1991 Z28
Axle/Gears: 9 Bolt 3:73
how much for the pistons, rods and crank?
Old Aug 12, 2010 | 04:56 AM
p-balin432's Avatar
Car: 92 Z/28...many more !
Engine: LY6 / pro charger
Transmission: 4L70E 5000 stall
Axle/Gears: Moser 9" 3.89 gear
i would like the miniram if for sale ! 434-944-7383
Old Aug 18, 2010 | 05:37 PM
p-balin432's Avatar
would still like to get the miniram ... cash in hand will drive up and pick it up and fuel rails 434-277-9135 or 434-944-7383
Old Aug 24, 2010 | 07:01 AM
decotrain's Avatar
Car: 91 RS, 84 Z28
Engine: 94 LT1, 383
Transmission: 700R4, Super T-10
Axle/Gears: 3:73, 3:56
this guy may not check this websight very often, you may get a response if you contact him thru the email address he left in his post. im not trying to be a smart ***, i just noticed there has not been any response from him.
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
86White_T/A305
Aug 17, 2015 12:16 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
