357 TUNED PORT! FIRST TO THROW DECENT OFFER GETS IT!!
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
I have a 350 tuned port injection 2pc rear seal engine for sale. Still in car running. (Im doing a ls1/700r4 swap that is why i am selling) You buy it you get everything!
From engine, to harness, to intake, to maf.
Engine Parts (all parts are either NEW! or REBUILT!)
Block
Stock cast, .040 over, Cleaned, honed, and blueprinted.
New stock CRANK
New stock 4v Pistons
New stock rods
New bearings
New rings
New Cam
New double cloyes timing chain
New aluminum timing chain cover
New lifters
New pushrods
New proform 1.6 roller rocker arms
New aluminum valve covers
Ported intake
Rebuilt throttle body
Ported/milled heads
New valve springs
New Headmen longtubes
New water pump
New alternater
New starter
New LT1 injectors
New msd blaster coil
New accel cap an rotor
New acdelco sparkplugs
ALL new felpro gaskets
New head bolts
New harmonic balancer
New allen headed bolt kit (polished)
Prolly other stuff just Not thinking
Here are a couple picstuckedup.jpg?t=1269978747
Block
New stock CRANK
New stock rods
New bearings
New rings
New Cam
New lifters
New pushrods
Ported intake
Ported/milled heads
New valve springs
New water pump
New alternater
New starter
New LT1 injectors
New head bolts
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: 357 TUNED PORT! FIRST TO THROW DECENT OFFER GETS IT!!
PM sent.
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
http://www.youtube.com/watch?v=esuWA7ALbV4 this is a link to hear the motor.
No the cam is not stock. it is a comp cam 12-268-4 C
Valve lift: EX:480 INT:477 LOBE ANGLE 114 Advance: in:270 Ex:280
PRICE IS OFFER> AS TITLE SAYs
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
I would honestly like 1000 or somewhere in that range but offer it up
Car: 1972 GMC
Engine: 355
Axle/Gears: 4:10
Is this a Tune port engine, does it have one piece rear seal, what heads does it have.
thanks
JC
thanks
JC
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
I also would like to know what heads are on it.
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
The motor was from a 85 vette. so whatever camewith it from factory but have been miled and ported. and it is a 2pc read the thread
Car: Firechicken
Any receipts from the build?
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
I do not no, i did not plan on selling so i threw them away
Car: 1991 Camaro RS
Engine: 305 Small Block
Axle/Gears: Factory
how much? i want it for my 91 camaro, does it come with wiring harness and computer
hectre13
Sep 8, 2015 03:38 PM
