[MA] B&M 144 roots blower setup for sale
Old Jul 31, 2010 | 12:17 AM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
i am guaging interest in my B&M 144 roots blower setup with 2 upper pullies and 2 belts.one for 5 psi and the other for 10 psi......will come with all hardware necessary.
1300.00 plus shipping..........
Old Jul 31, 2010 | 09:28 AM
Re: Guaging interest--B&M 144 roots blower setup
i also have a complete new in package rebuild kit for it as well..... will let the whole package go for 1450.00 with the rebuild kit plus shipping
Old Aug 2, 2010 | 10:26 AM
im looking for a turbo kit.will consider trades
Old Aug 2, 2010 | 04:16 PM
davef249's Avatar
Want a title? Post!
any trades at all? ifnot can we do a cheaper cash price? i live in pembroke mass so pick up isnt a problem .. if you could email me it would be alot easer davef249@msn.com
thanks dave k
Old Aug 3, 2010 | 06:36 PM
email sent
Old Aug 4, 2010 | 01:32 AM
Saintanger1981's Avatar
Car: 1992 RS
Engine: 350, Trick Flow Twisted wedge heads
Axle/Gears: 3.45 9 bolt coming soon
If only my tranny on my suburan hadnt gone out..
Old Aug 4, 2010 | 08:44 AM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
I am possibly interested the only thing is whether or not i can use it on my set up. Will a roots set up work with a tbi 305?
Old Aug 4, 2010 | 09:04 AM
i dont see why it wouldnt work.you would have to raise the fuel pressure i would think
Old Aug 4, 2010 | 09:12 AM
keep in mind that you'll have to get an adapter plate to mount your throttle body on top of a supercharger, then fabricate a bracket for your throtte,tv,and cruise cables. and, you may want to upgrade to a 670 throttle body.
Old Aug 4, 2010 | 09:30 AM
Engine: Built ls1
Axle/Gears: 3:42
I have the adapter plate and fuel pressure regulator with the 670 cfm tbi and larger fuel pump. I just dont want to buy it and then find out that it wont work. I have been searching to see if anyone has done this yet but have not found anything.
Old Aug 4, 2010 | 10:27 AM
well if you want i can put together a 700 sc carb for an additional 300.00...............i dont need the 700cfm since im running an 850 cfm carb now......i can let the carb, roots blower with complete(new) rebuild kit i have as a spare and both the pulleyt setups go fo 1900.00 shipped...........new this would be 3400.00............
Old Aug 4, 2010 | 12:46 PM
Engine: Built ls1
Axle/Gears: 3:42
I am not looking to go to a carb set up. I have been told by Rbob that the tbi will work with the supercharger so my interest in your setup has become more serious. I need to do a little more research before I go any further, I will get back to you.
Old Aug 4, 2010 | 01:05 PM
ok no problem i was just throwing the option out there if you needed a carb........i would like to see someone buy this but i dont want to be low balled(no disrespect intended) i appreciate the interest.
Old Aug 4, 2010 | 01:41 PM
Engine: Built ls1
Axle/Gears: 3:42
what size cowl do you have. I want to know how much room i need/have for the setup?
Old Aug 4, 2010 | 02:30 PM
i run a 3 " cowl.........with a 3" total height air cleaner assembly with 1/2" to spare for clearance but thats with a carb setup....you could run a low profile air cleaner setup if necessary...
Old Aug 5, 2010 | 10:27 AM
to the top
Old Aug 5, 2010 | 04:34 PM
Engine: Built ls1
Axle/Gears: 3:42
can you tell me what the price would be with shippng to 11754? I am working on getting funds together as I am very interested at this point.
I do have another question. I notice that you have the older style dual belt set up, Am i going to run into a problem because I have the single belt serpentine set up, as in will belt alignment be an issue?
Old Aug 5, 2010 | 08:39 PM
pm sent......
Old Aug 7, 2010 | 04:37 PM
bump
Old Aug 7, 2010 | 09:21 PM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
trades for a 355 short block thats ALL NEW never turned
Old Aug 7, 2010 | 10:22 PM
pm me complete details on it and some pictures too thanks
Old Aug 8, 2010 | 09:57 PM
ttt
Old Aug 10, 2010 | 07:04 AM
bump for this morning
Old Aug 11, 2010 | 11:36 PM
Re: B&M 144 roots blower setup for sale
bump.no one wants a blower?
Old Aug 12, 2010 | 07:40 PM
i will do 1475.00 shipped in the usa for the blower , pulley setups and the spare rebuild kit
Old Sep 21, 2010 | 08:57 AM
bump. 1400.00 shipped in the usa....anyone???
Old Sep 21, 2010 | 03:43 PM
CAMAROJOKESTER's Avatar
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
pm'ed you
Old Sep 21, 2010 | 05:21 PM
replied back
Old Sep 21, 2010 | 05:48 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
Back at you.
Old Sep 21, 2010 | 07:55 PM
pm returned.....
Old Sep 22, 2010 | 08:08 PM
bump
Old Sep 23, 2010 | 04:09 PM
to the top
Old Sep 24, 2010 | 01:50 PM
to the top for this afternoon
Old Sep 24, 2010 | 08:08 PM
ill do 1250.00 shipped in the usa....WITHOUT the complete rebuild kit.
Old Sep 24, 2010 | 08:12 PM
j88l98irocz's Avatar
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
Any horsepower numbers at 10lbs?
Old Sep 24, 2010 | 08:23 PM
no sorry.never had it dynoed...........i just know it was a difference from the 5 lb setup......
Old Sep 24, 2010 | 08:56 PM
Transmission: t56
1/4 mile times....?
Old Sep 24, 2010 | 09:01 PM
the individual who i bought the blower from ran a 355 with under 9:1 comp, holley systemax heads and a mild cam in a 81 malibu ran 11.93 in the 1/4 mile with the 5 lb setup...............im runnin almost 10:1 with 10 psi and bigger heads and def way bigger cam.......im sure it could pull off 11s no problem b ut i havent had time to go to the track since i work alot and raise a family...............
Frozer!!!
Jan 19, 2024 04:55 PM
stalkier
Dec 6, 2015 11:25 PM
CORV3TT3
Aug 23, 2015 11:26 AM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
