T5 BORG WARNER TRANSMISSION V6 AND V8
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
Hi, i have 2 transmissions ...one T5 for a V6 5 speed with bellhousing and shifter ,,came out of running car and ready to install with 14 splines...
the 2nd is a V8 T5 with 26 splines and is in good shape and shifts through the gears very well and easy...the input shaft has some loose in it, i guess replacing the input shaft bearing is required...make an offer...these are light trannys and can be shipped anywhere at a reasonable shipping cost.
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
