Parts off a L98 350
1 Post
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Parts off a L98 350
Need to clean out the garage, shipping not included in the prices, offers are accepted:
Lucas 24lb Injectors, work great $70
Stock Bosch 22.7lb Injectors $25
1988 Auto/350/CSI Delete/Smog Delete/EGR Delete Custom Burnt Memcal $75
TPI Intake Baseplate $40
TPI Runners $30
TPI Plenum $25
Powder Coated Charcoal Stock 48mm TB w/ Red Anodized "GTA" TB Plate and Stainless Steel Bolts $50
SOLD SLP Air Foil $20
"GTA Trans Am" Polished TB Plate Brand New $10
Fuel Rail Mounted Fuel Pressure Gauge (Gauge+3 fittings) $30
GM Starter $20
Edelbrock Chrome Breather Brand New $10
Near New IAC Valve (500 kms)$30
Near New TPS Sensor (500 kms) $30
350 Manifolds $30
Entire AC System (was deleted properly) $40
GM Waterpump $15
Firebird Air Intake w/ K&N Filter and hoses $45
SOLD Helix Power Tower TB Spacer $15
MSD 8.5mm Super Conductor Wires (1000 miles)$70
700R4 Dip Stick $10
EGR Valve w/ Solenoid (was deleted properly) $20
TPI Runners $30
TPI Plenum $25
GM Starter $20
350 Manifolds $30
GM Waterpump $15
700R4 Dip Stick $10
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
Re: Parts off a L98 350
I am restoring a yellow 92 GTA and I am looking for the following parts:
1. 3 throttle body coolant clamps for 1985-92 TPI cars. I have tried buying them new but the 2 part numbers I have are for worm style clamps. I am looking for clamps in good condition that aren't rusty. Here are some pics:
2. 14 mm bolt and metal clip that holds the alternator wiring. I believe that all 88-92 TPI cars came with these parts. There is no part numbers available for these parts so I am looking for good condition, rust free parts. Below is a picture for the bolt and clip.
3. SLP air foil - would you be willing to separate it from the thottle body, if so how much would you want for it
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Very interested in the throttle body package and fp gauge. Pm me pictures or via email @ mares773@gmail.com
Was this tb from your 88? I assume its the older style tps if so.
1 Post
Here's the runner pics for Mike.
1 Post
Engine: L98 TPI 5.7L 350
Transmission: 700R4 Automatic
i know its been a while, wondering if u got a neg bp egr valve,.temp switch, or 9th injector. thanks.
1 Post
I don't have an 9th injector anymore. But I do have an egr valve. Which temp switch are you looking for?
1 Post
egr temp switch. do u happen to have the part number on hand for the egr valve? pretty sure its the right one if its off the 88. how much to ship to 92585? thanks.
